Horizontal Stabilizers-Rebel
Roger & Alice Hoffman
Post by Roger & Alice Hoffman » Fri Feb 17, 2012 5:56 pm
I'm about to finish the horizontal stabilizers and was wondering if anyone
recommends (or not) putting an access/inspection plate in the bottom skin to
access/inspect the bolts/nuts of the (inner) elevator hinge, rear stabilizer
attach bracket, and the strut attach bracket?
Roger #687R
Eugene, OR USA
Post by Bob Patterson » Fri Feb 17, 2012 5:56 pm
Roger,
Most builders here have decided to add inspection covers later,
IF and WHEN they are needed. The trim tab servo is usually mounted on
a separate plate, so it can be removed easily, if needed. (nobody has
had a problem yet ...)
--------------------------------orig.---------------------------------------
Roger #687R
Eugene, OR USA
rebelair
Post by rebelair » Fri Feb 17, 2012 5:56 pm
Hi Bob
Nobody has had a problem yet with the trim tab servo because it goes so long
without use. I know I am just kidding you, but seriously, in most flight
situations with just varying fuel loads and passengers, the trim has been of
little value. As Wayne points out, with a great deal of baggage i.e. a lot
of weight aft, it may come more into play. I have not experienced this yet.
Regards
Brian #328R
Sent: Thursday, June 08, 2000 12:52 PM
Subject: Re: Horizontal Stabilizers-Rebel
Roger,
stabilizer
Roger #687R
Eugene, OR USA
Mr. Baker,
You wrote: "My solution, confirmed by Murphy,
was a 5/8" hole located at the "V" in the stabilizer. A short 3/8"
socketwith universal can access all 4 of the hinge bolts for torque
checking. "
What covers the hole? and did you put a doubler behind it or no?
Thanks for your help.
Roger #687R
Eugene, OR USA
Brian,
Maybe you'll get a chance to exercise your trim servo if you can
come on the Ramble !! ;-)
We certainly will have a LOT of camping gear & 'stuff' for this
one !! But, you're right - even with that load, it only takes a couple
of taps on the trim button, and then we leave it alone ... Isn't this
GREAT ??!! (not at all like a CessPool) :-)
....bobp
-----------------------------orig.----------------------------------------
At 04:24 PM 6/9/00 -0400, you wrote:
Hi Bob
Regards
Brian #328R
Roger,
stabilizer
Roger #687R
Eugene, OR USA
