tail ski
Posted: Fri Feb 17, 2012 8:56 pm
In a message dated 6/3/00 9:56:55 PM Central Daylight Time,
oifa@irishfield.on.ca writes:
<< The other great benefit
of not running a tail ski is, that when you start to run out of runway you
can haul back on the stick forcing the tail wheel into the snow to use as a
brake. Yes you might break the tail spring (if you use those fiberglass
ones), but it is better than taking your wings off in the trees!!!!! >>
WAYNE
Is that the voice of experience? About tail wheel springs was it you that
said they where using a modified trailer spring from Prince auto, If so I
would like to bother you for some info on the installation and part # of
spring. Also I'm about to order a full swiveling tail wheel any one out there
have any suggestions.
Phil&Lisa Smith #460 N414D
WAYNE
