[rebel-builders] spray rails
Posted: Sun Feb 19, 2012 12:12 pm
by John Kramer
Garry,
If I was building or repairing a set of floats I'd first buy Wayne's
CD of how to do it. I'm still waiting for his fuselage CD to be finished.
John... 369R
At 02:24 PM 6/27/2007, you wrote:
Some of you will remember that the floats for FOKM were damaged nearly 2
years ago and have been in repairs since. The chap doing the repairs is
at the spray rail stage and considers the amount of bending and
stretching of the material provided by Murphy to get to the compound
curve to be excessive and beyond any reasonable requirement. He also
says that more recent designs have the spray rails vertical, keeping the
spray more confined than the originals would.
1. Does anyone have comment on the amount of work to make these fit and
the tools etc required to get them there? How was it handled on float
kits that people have built? We don't have the instruction manual for them.
2. Does anyone have comment on the vertical rail suggestion?
Garry
068R
Fly too low or too slow and the ground will rise up and smite thee.
by Drew Dalgleish
Hi Garry My floats have vertical spray rails at the front inside of each
float to keep spray away from the prop. Just ahead of the step there's
spray rails sticking out both sides and bent down about 30 degrees. No
compuond curves on any of them. The ones at the step are there more as lift
devices than to control spray and there has been some discussion about
leaving the outside ones off or cutting them down to prevent damage from
docks.
Garry
068R
by Bob Fisher
hi gary I would build them vertical the way they are now out on an
angle is a pain in the butt at docks and for banging you legs against
they are effective though for spray reduction bob fisher rebel 342
Sent: Wednesday, June 27, 2007 3:24 PM
Subject: [rebel-builders] spray rails
them.
Garry
068R
by Garry Wright
Thanks to all who replied. If we were building new I would be strongly
attracted to the vertical rail idea. As it is, adapting to vertical is a
pretty ugly kludge. Not sure what to do.
Garry
them.
Garry
068R
by Drew Dalgleish
Hi Garry I'm going to drag my camera over to the hangar this afternoon
would some pictures help?
Garry
them.
Garry
068R
by Garry Wright
Hi Drew,
I would appreciate that a great deal. Direct to
garry@davincibb.net
would be great. Thanks.
Garry
Garry
by Robert Andrews
Gary,
Have zero 1800 construction experience, but perhaps some 2200 pics will
help?
www.aacnet.com/elite/2006-06-01
Bob 612e
Garry Wright
Sent: Friday, June 29, 2007 7:37 AM
Subject: Re: [rebel-builders] spray rails
Hi Drew,
garry@davincibb.net
Garry
Garry
2
by Garry Wright
Hi Bob,
That helps. You have the right angle channel as a continuous piece,
stiffening the edge by effectively doubling the other right angle
channel but also to hold the spray rail. How far back did you run the
spray rail from the front of the float - I can't tell from the picture.
Garry
Robert Andrews wrote:
Gary,
help?
Bob 612e
Garry Wright
Hi Drew,
garry@davincibb.net
Garry
Garry
Bob Fisher wrote:
2
by Robert Andrews
Gary,
The exact distance to run the rail from the front of the float is likely not
the same for your 1800's. But the first picture in the set (link) below may
give you an idea ratio wise of were to run it w/r/t your fwd spreader bar
location.
www.aacnet.com/elite/sprayrails
The spray rail itself is a cut-to-fit piece from 0.040" 6061-T6 sheet stock.
The 90 degree angle piece the sprail rail is mounted to, has one side worked
with a shrinker to bend it to match the shape of the float chine.
Hope this helps ...
Bob 612e
Garry Wright
Sent: Friday, June 29, 2007 8:35 AM
Hi Bob,
Garry
Gary,
help?
Bob 612e
Garry Wright
Hi Drew,
garry@davincibb.net
Garry
Garry
Bob Fisher wrote:
an
2
is
Posted: Sun Feb 19, 2012 11:37 pm
Floater docks... they're a non issue. Some crib docks though you have to be
vigilant.
Sent: Friday, February 03, 2012 8:36 PM
Hi Thanks for the input on the rails. They perform great , but I was
concerned about docking & the fact that I`ve never seen another float with
the outside railsPutting the saw away for now ,probably falls into the
category of aint broke. don`t fix. Bill
by drewjan
The real problem with docking is that the side skins are only .020 and not anywhere near tough enough to leave your plane unattended without a spring line to hold it off the dock.
Sender: mike.davis@dcsol.com
Date: Fri, 03 Feb 2012 20:36:44
Hi Thanks for the input on the rails. They perform great , but I was concerned about docking & the fact that I`ve never seen another float with the outside railsPutting the saw away for now ,probably falls into the category of aint broke. don`t fix. Bill
I think the best I ever did.. and it was by fluke Drew.. those "rolling
tire" docks I made for everyone when Walter and Al came to visit in
Temagami. Worked like a charm.. never left a mark.... until the ice broke
them on me. I'll look for a picture to post.
Sent: Friday, February 03, 2012 10:52 PM
by Walter Klatt
Actually, the best was that air lift you had there, to lift the plane right
out of the water. Sure helped with the oil change I had to do on the water.
And I guess it saved your plane from that storm a few days before.
G. O'Shea
Sent: Friday, February 03, 2012 8:23 PM
2 x 10 and 2 x 8 joined together to make a 90* and then bolted to the end of
finger dock. Tires slipped over and they roll as the airplane goes up and
down in waves. Worked GREAT!
http://www.irishfield.on.ca/gallery/rollingtiredock.jpg
Sent: Friday, February 03, 2012 11:23 PM
not
spring
with
Yah.. the wharf master is pretty too....
http://www.irishfield.on.ca/gallery/djkleah.jpg
Sent: Friday, February 03, 2012 11:48 PM
Subject: RE: [rebel-builders] spray rails
right
water.
G. O'Shea
not
spring
with
