[rebel-builders] Rebel elevator trim instructions
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 3:12 pm
Works both ways, geoff
Mine is under but it makes no difference other than looks
Mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Geoff
van Asch
Sent: June 19, 2007 6:58 AM
To: rebel-builders-d@dcsol.com
Subject: [rebel-builders] Rebel elevator trim instructions
Hi all
I'm a very new - green builder quietly chipping away at the build
process.
I've been using the archived files on Mikes site for reference where
need be, they have been very helpful.
I am currently doing the trim on the elevator
The instructions show the hinge on top of both the elevator and trim
skins.
Is it possible to have the hinge between the spar and the skins?, i.e. a
clean flowing skin with the hinge underneath??
In NZ of the 5 or 6 rebels I have seen half are each way.
Apart from the instructions saying so has any one found a reason why the
hinge is / needs to be on top of the skins??
It looks cleaner and tidier underneath!
Comments please to the Kiwi Boy down-under!!!
Regards
Geoff van Asch Rebel 798
Post by Ken » Sun Feb 19, 2012 3:12 pm
Hi Geoff
FWIW putting the hinge on the bottom surface will make the electric
actuator even more sensitive and it is fairly sensitive already even
with the push rod in the outboard hole of the horn. Personally I think
it looks better with the hinge on the top surface but with the hinge pin
facing down if that is what you mean. I'd avoid putting the hinge on
the bottom with the pin side of the hinge facing down as that might
induce premature airflow separation in the full up position and I use
full up on every landing,...
Geoff van Asch wrote:
Hi all
process.
skins.
Regards
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 3:12 pm
Hi Geoff: Yes it looks much neater under the skin: - I have done three that
way now. - Keep plugging away - it is a great flying machine. Bob J - Rebel
192/731
To: <rebel-builders-d@dcsol.com>
Sent: Tuesday, June 19, 2007 6:57 AM
Rick Harper
Post by Rick Harper » Sun Feb 19, 2012 3:12 pm
G'day from OZ Geoff !
I cant see any reason why you can't "hide" the hinges ...
Obviously make sure that they will not bind or catch anywhere .... but I can't think of any structural differences / problems associated with the idea !
Rick "Biggus" Harper
541R
(in Sydney)
Sent: Tuesday, June 19, 2007 8:57 PM
Hi all
process.
skins.
Regards
Geoff van Asch
Post by Geoff van Asch » Sun Feb 19, 2012 3:12 pm
Hi Ken
I think we might be at cross purposes!
Hinge is still on top of the trim, but just under the skin.
Seems like the other responses to date seem OK with that, if anyone out
there isn't yell before I start making #40 holes bigger
Geoff R798
Date: Tue, 19 Jun 2007 07:53:35 -0400
To: rebel-builders
Subject: Re: [rebel-builders] Rebel elevator trim instructions
Hi Geoff
Geoff
Yes I seem to be having trouble understanding the posts lately but still
trying to help ;)
Hi Ken
Geoff R798
