[rebel-builders] Door Windows
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 12:08 pm
Hi Gary: The material I have for my Rebel is 3/32 which is the same as the
scraps left over from the Moose skylights. You should be able to get it from
any plastics supplier. Clear is never a problem, but the "smoked" has to be
bought in large quantity. Its to bad where so far apart as I have more
around here then I will probably ever use and would give you what you need.
The Rebel kit I am working on, being an older kit came with enough extra
material for the windshield but I bought a newer preformed one from Murphy.
Shipping would probably cost more the buying some locally. That is an option
if you have any trouble. Best regards. Bob J Rebel 192/731
Sent: Wednesday, May 30, 2007 8:48 AM
Subject: [rebel-builders] Door Windows
The passenger side window of my plane has been damaged by dripping of
lacquer thinner on it. (I didn't do it for a change.) The manual simply
refers to it as lexan but does not specify thickness. So that I don't
have to take it apart to find out (and can leave it in service until
material is available), can someone please measure the thickness of the
window material and let me know?
Any suggestions as to where to buy such a piece in Canada would be
helpful too. Thanks.
Garry
068R
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 12:08 pm
Hi Gary, the sheet I have is 1/8th, High Performance, and is made by GE
products. The label says they have manufacturing in Cobourg Ontario and
there's also a phone number but I don't know how current it is -
1-800-451-3147.
Jim - 333R
Garry
068R
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 12:08 pm
Try GE Polymershapes. Shud have an outlet in Calgary.
Steve W 637R
To: "rebel-builders@dcsol.com" <rebel-builders@dcsol.com>
Subject: Re: [rebel-builders] Door Windows
Date: Wed, 30 May 2007 10:01:15 -0400
1-800-451-3147.
Jim - 333R
Garry
068R
Windows Live Hotmail is the next generation of MSN Hotmail.
bransom
Post by bransom » Sun Feb 19, 2012 12:08 pm
Remember too that lexan is brand name for polycarbonate ...just in case
what you find is not specifically lexan.
-Ben
Garry
068R
Windows Live Hotmail is the next generation of MSN Hotmail. It
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 12:08 pm
Thanks Bob, Jim, Steve and Ben. Will chase that down.
Garry
-Ben
Post by Wayne G. O'Shea » Sun Feb 19, 2012 12:08 pm
Don't be so quick to make Dupont's Lexan generic for Polycarb. Lexan can be
bent in a brake..cut with tin snips. If you buy generic polycarb sheet and
try that...well lets just say don't!
;O)
Sent: Wednesday, May 30, 2007 3:39 PM
-Ben
Windows Live Hotmail is the next generation of MSN Hotmail. It's fast,
simple, and safer than ever and best of all - it's still free. Try it
today!
www.newhotmail.ca?icid=WLHMENCA146
Post by Drew Dalgleish » Sun Feb 19, 2012 12:08 pm
Hi Garry If I needed to replace my side windows I think I'd go a little
thicker than what I have now in order to try and make the plane a little
quieter.
Garry
068R
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 12:08 pm
In the booklet "How to Soundproof Light Aircraft" available from
http://www.soundproofing.org (also via ACS) they are very clear that one
of the the best things you can do to reduce noise is use thicker window
material.
Garry Wright wrote:
Does quieter actually follow thicker? I am looking at ways to lower the
racket other than active headsets which do a commendable job by the way.
Has anyone actually verified this?
Ron Shannon
Should add they confirm thicker windows (and doors) attenuate not only
with engine noise, but also wind and prop generated noise, which are
major elements in most planes. The trade off is weight, of course.
material.
Garry Wright
Hi Steve. I'm so far over budget that I'm working on stuff that doesn't
cost much. Hmmm. If my wife knew she would likely faint,
Garry
steve whitenect wrote:
Gary
I used an exhaust system from aircraft technologies which have cross over
pipes into two mufflers and also two heat muffs. Around $1100 us and very
quiet. With the ANR head sets, it's very, very quiet.
Steve W. 637R
Date: Thu, 31 May 2007 20:53:25 -0600
Thanks Richard, Drew and Eddie. I will look at what GE offers and go
from there. Noise is definitely a concern.
Garry
Drew Dalgleish wrote:
I think so but can't cite any proof other than it seems to be a popular
option for spam cans.
At 07:56 PM 5/31/2007 -0600, you wrote:
way.
Canada?
little
little
simply
Windows Live Hotmail with drag and drop, you can easily move and organize
your mail in one simple step. Get it today!
www.newhotmail.ca?icid=WLHMENCA153
Garry Wright
Drew,
There is an article in Kitplanes this month on a foam material
'polyvinyl nitride' which does a good job and complies with FAA
requirements on fire resistance. Does anyone know of a source in Canada?
My originals are only 1/16" thick and barely manage to hold snapvents
sort of.
Garry
quieter.
Garry
068R
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 12:08 pm
YES!
C-Bailey Long Beach CA. offered a 1/4" windshield in place of a 3/16"
for a 172 and it was definitely quieter. Just a bit harder to install
if you didn't drill off the bottom retainer strip. So the same should
be true for noise on the side windows
Dick Wampach SR-108
Garry Wright
Sent: Thursday, May 31, 2007 6:56 PM
Drew,
sort of.
Garry
little
little
quieter.
simply
Garry
068R
Eddie Moran
Post by Eddie Moran » Sun Feb 19, 2012 12:08 pm
Hey guys,
I have two smoked, bubbled side windows for sale. I bought the "Window Kit" from MAM and paid over $777 for the "set". I do not need the two side "main" windows. I just used the other ones.
The windows were made in 07 and I can send pics with measurements.
The windows do NOT have frames with them.
With the window kit costing $770 and consisting of eight windows............the two big side ones (that I am selling), the next three side windows (per side) that I used I would compute the value of the two smoked, bubbled, side windows as $400 for the two.
These windows would be very cool. I have clear bubble windows already and do not want to screw with them.
Eddie Moran
N320VT or N240MM
quieter.
Garry
068R
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.
Drew,
sort of.
Garry
quieter.
Garry
068R
Garry Wright
Garry
Drew,
sort of.
Garry
quieter.
At 06:48 AM 5/30/2007 -0600, you wrote: Drew
