[rebel-builders] Engine mount bolts
Posted: Sun Feb 19, 2012 12:08 pm
by Jim Cole
Anybody heard from Bob lately - Back yet Bob???
Are we having a builders club meeting tomorrow in Brampton?
If Bob's not back I can bring some donuts.
Let me know.
Jim
Rebel 333
On 5/26/2007 11:56 AM, "Jesse Jenks" <
jessejenks@hotmail.com> wrote:
I don't seem to have the correct length bolts to attach the mount to the
fus-85/86. Since I have to order some, I am wondering if I can use all-metal
high temp lock nuts, or if I have to use drilled bolts and cotters?
The issue seems to be that there will be minimal clearance between the upper
bolts/nuts/washers, and the inside of the cowl. I don't want to have to
stack multiple washers to align a cotter with the hole.
Thanks.
PC Magazine‚s 2007 editors‚ choice for best Web mail˜award-winning Windows
Live Hotmail.
http://imagine-windowslive.com/hotmail/ ... _migration_
HM_mini_pcmag_0507
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Unsubscribe:
List administrator:
by Ken
My mount bolts to the firewall with AN5 bolts with metal locknuts on the
FW side. Since the bolts don't move and are torqued tight there would
seem to be no reason to use castle nuts and cotter pins unless you
wanted to.
Thanks.
Unsubscribe:
List administrator:
by Jesse Jenks
Thanks Ken,
Also I wanted to ask about how most people deal with the bolts once the
fus-85/86 are bolted together and riveted into the fuselage. The bolts are
semi permanently held captive by the 3/16" bolts holding the fus-85/86
together, so if you want to remove the mount, do you just leave the bolts in
place and pull the mount off? Also, how do you hold the bolt head while
torquing the nut? A normal open end wrench won't fit inside the fus-86. The
only thing I can think of is to modify a wrench to fit.
Thanks again.
klehman@albedo.net>
Reply-To: <
rebel-builders@dcsol.com>
To:
Subject: Re: [rebel-builders] Engine mount bolts
Date: Sat, 26 May 2007 17:55:54 -0400
wanted to.
all-metal
upper
Thanks.
Unsubscribe:
List administrator:
PC Magazine
by Mike Betti
That's how my mount was if I remember correctly, slide it off the bolts. I
think I may of just used a screwdriver blade or such and wedged it against
the flat of the bolt. It doesn't take much to hold them.
To: <
Sent: Sunday, May 27, 2007 12:20 PM
Thanks Ken,
in
The
Thanks again.
klehman@albedo.net>
Reply-To: <
To:
wanted to.
all-metal
upper
Thanks.
Unsubscribe:
List administrator:
PC Magazine's 2007 editors' choice for best Web mail-award-winning Windows
Live Hotmail.
http://imagine-windowslive.com/hotmail/ ... pcmag_0507
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
by Drew Dalgleish
I used drilled bolts with castle nuts and too many washers probably because
that's the way the tri-pacer I took apart was built. A screw driver can be
used to jam the bolt head while you tighten the nut. The local maintenance
shop has been very good to me as a source for small quantities of hardware.
They charge a lot more than spruce but if I pay cash the taxes magically
dissapear plus I save on shipping and have my parts right away.
At 10:20 AM 5/27/2007 -0700, you wrote:
Thanks Ken,
Thanks again.
klehman@albedo.net>
Reply-To: <
To:
wanted to.
all-metal
upper
Thanks.
Unsubscribe:
List administrator:
PC Magazine
by Ron Shannon
Jesse,
Used a screwdriver flat here too. Even though the screwdriver flat isn't
all that secure a fit to the bolt head, once the bolt head gets snug,
there's enough friction to keep it from turning.
FWIW, I'm using NAS 6604 bolts (a little lighter, stronger than AN) and
self locking high temp metal nuts (MS21046C), available from
http://www.gen-aricraft-hardware.com
Unsubscribe:
List administrator:
by Ron Shannon
Correction, they're NAS1291C nuts.
Ron Shannon wrote:
Jesse,
Unsubscribe:
List administrator:
by Ron Shannon
Oh geez, they are not! They're MS21043. I hate it when this happens
(foot in mouth disease).
Unsubscribe:
List administrator:
by Jesse Jenks
Thanks Ron and Mike.
PC Magazine
by Jesse Jenks
And Drew, Thanks!
drewjan@cabletv.on.ca>
Reply-To: <
To: <
Date: Sun, 27 May 2007 15:33:43 -0400
Thanks Ken,
are
in
The
Thanks again.
klehman@albedo.net>
Reply-To: <
To:
wanted to.
Jesse Jenks wrote:
PC Magazine
