Engine mount bolts
Jesse Jenks
Engine mount bolts
Post by Jesse Jenks » Sun Feb 19, 2012 12:08 pm
I don't seem to have the correct length bolts to attach the mount to the
fus-85/86. Since I have to order some, I am wondering if I can use all-metal
high temp lock nuts, or if I have to use drilled bolts and cotters?
The issue seems to be that there will be minimal clearance between the upper
bolts/nuts/washers, and the inside of the cowl. I don't want to have to
stack multiple washers to align a cotter with the hole.
Thanks.
Jesse
PC Magazine
