[rebel-builders] Panel Dimensions
Post by Bob Patterson » Sun Feb 19, 2012 3:04 pm
Hi Rich !
Sorry - can't get dimensions for you now ... someone will
surely beat me to it anyway...
Don't forget to add a 2" channel, or angle, all along the
bottom of the panel, tying into the door posts, with the
middle angles bridged. You need this to stiffen up the
panel, and to give you space to mount the throttle,
primer, mixture, trim switch, and maybe the key,
etc. ... The panel is just deep enough for 2 rows of
instruments, and could use some stiffening anyway.
(Angle can be 1 1/2" - 2", & up to 1/8" thick)
The panel IS part of the structure - if you just run the
throttle through the panel, and don't add the channel
& stiffeners, the fuse will flex enough that the throttle
will move in & out on rough ground ... even if you
hold it completely closed !
If you cut the instrument holes about 1/4" oversize,
and add channels to the back for stiffness, you can
mount the instruments to an .040+ panel that can float
on top of the base panel, with the instruments through
those lage holes, and the floating panel supported by
rubber shock mounts. This helps the durability of
the gyros, and makes it a LOT easier to work on the
instruments - just pull the floating panel down to get
at the connections. This is MUCH easier than trying to
crawl underneath ! :-) The left angle panel can have
a rectangle cut out - as long as the rear of the panel
is reinforced with doubler angles. This swing out panel
(on a couple of piano hinges) is great for mounting
electrical breakers & switches for easy access.
http://www.prosumers.ca
On Sunday 13 May 2007 23:18, Rich Dodson wrote:
Gents,
Could you do me a big favor and email me the width and height of the
standard Rebel panel (all three sections)?
Thanks a bunch!
Rich
Rebel 806
Rich Dodson
Post by Rich Dodson » Sun Feb 19, 2012 3:04 pm
Thanks a bunch Bob!!!
----- Original Message ----
Sent: Sunday, May 13, 2007 8:19:32 PM
Subject: Re: [rebel-builders] Panel Dimensions
Hi Rich !
Gents,
Thanks a bunch!
Rich
Rebel 806
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 3:04 pm
Hi Rich. The panel height is 8" with the sides being 10" each and the center
26". The sides have the 1" flange also for attaching to the door posts. If
this is not understandable let me know. Bob J Rebel 192/731
To: "Rebel Listserve" <rebel-builders@dcsol.com>
Sent: Sunday, May 13, 2007 7:18 PM
Subject: [rebel-builders] Panel Dimensions
Gents,
Thanks a bunch!
Rich
Rebel 806
Post by Wayne G. O'Shea » Sun Feb 19, 2012 3:04 pm
If you cut the firewall back by 3" the side panels become shorter by 2
inches.
Sent: Sunday, May 13, 2007 9:00 PM
center
Gents,
Thanks a bunch!
Rich
Rebel 806
Rich Dodson
Thanks Bob and Wayne!
Sent: Sunday, May 13, 2007 9:00:43 PM
rshannon
Post by rshannon » Sun Feb 19, 2012 3:08 pm
Has anyone managed to squeeze (3) 2 1/4" instruments vertically in the
Rebel panel?
Ron
254R
http://n254mr.com
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 3:08 pm
Hi Ron: Per an AutoCAD layout I just did, it is quite possible within the 8"
panel height - HOWEVER - it will not work on the sides where the 5/8 square
tubing is mounted for the panel braces. You could stagger them a bit side
to side - may be quite effective.- Bob J Rebel 192/731.
Sent: Monday, May 21, 2007 1:22 PM
Rebel panel?
Ron
254R
http://n254mr.com
Post by Ken » Sun Feb 19, 2012 3:08 pm
Since I added a 2" channel under my Rebel panel, I wish I had put the
5/8 panel braces below the bottom of the panel (inside the 2" channel).
Done per the manual, those braces interfered with my bottom outboard
and even the bottom center instrument in a conventional six pack of
flight instruments.
Rebel panel?
Ron
254R
http://n254mr.com
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 3:08 pm
Thanks, Bob, for running the numbers, and Ken, for suggesting how the
bracing layout could be modified to optimize panel space. The panel is a
tight fit, especially for those of us who insist on including the
kitchen sink. :-)
flight instruments.
Post by Drew Dalgleish » Sun Feb 19, 2012 3:08 pm
If you want it all why not go for a glass panel? I think you can put in a
dynon or AFS for less than the price of steam gauges.
kitchen sink. :-)
flight instruments.
the 8"
square
side
Ron Shannon
I do plan (at the moment) to install dual GRT EFIS panels for primary
flight and engine instrumentation. However, there are other functions I
may want to implement in 2.25 round format in the panel, like Becker
transponder, X-COM VHF, DigiTrak A/P, vertical card compass, and
DigiTrak ADI when/if they finally get the 2.25 model out the door, etc.
kitchen sink. :-)
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 3:08 pm
That's what I plan to do.
Jesse
Date: Tue, 22 May 2007 19:51:56 -0400
kitchen sink. :-)
flight instruments.
the 8"
square
side
PC Magazine
Wow you really do want it all. Best of luck to ya and please give a report
on how well the A/P works out.
kitchen sink. :-)
Ron Shannon
It's still easy to dream big when your panel is still 9-10 months away.
Did I mention the FLIR scope? :-)
Post by Wayne G. O'Shea » Sun Feb 19, 2012 3:08 pm
I hear there's a 75K Moose panel kicking around now... that would rivet
right in.... ;o)
Sent: Tuesday, May 22, 2007 7:51 PM
kitchen sink. :-)
flight instruments.
the 8"
square
side
