drilling holes in a tube
Snader, Douglas E.
Post by Snader, Douglas E. » Fri Feb 17, 2012 5:56 pm
I have one more question what is the best way to measure and mark the
torque tubes for drilling the eight evenly spaced holes?
Doug Snader
"Elite # 582"
LisaFly99
Post by LisaFly99 » Fri Feb 17, 2012 5:56 pm
DOUG
Use a square piece of paper the same size or a little larger than the tube.
Mark the corners then move it 45deg. and mark them again.
Phil&Lisa Smith #460 N414D
Wray Thompson
Post by Wray Thompson » Fri Feb 17, 2012 5:56 pm
<!doctype html public "-//w3c//dtd html 4.0 transitional//en"> Try here http://webhome.idirect.com/~wrayt/rebman.html and go just past elevator figure 2 to step 6. ...basically wrap a piece of paper, mark it and divide it in 8.
Doug Snader
"Elite # 582"
Wray Thompson ...Rebel 306 ...home page http://webhome.idirect.com/~wrayt/
My ICQ number is 29764664
*-----------------------------------------------------------------------------------* The Murphy Rebel Builders List is for the discussion between builders and owners of Murphy Rebel aircraft. Archives located at: http://www.dcsol.com/murphy-rebel/lists/default.htm *-----------------------------------------------------------------------------------*
klehman
Post by klehman » Fri Feb 17, 2012 5:56 pm
Doug
I marked the end caps then tranferred the marks.
You may also want to stagger the eight holes that go in from the end relative to
the eight that go in radially to prevent the rivets interfering with each other
during installation.
Post by Bob Patterson » Fri Feb 17, 2012 5:56 pm
Very helpful info, Wray, but almost impossible to read !! Is there
any way you can turn OFF the 'produce HTML' function in your email
program ??
Thanks !! .....bobp
---------------------------orig.----------------------------------------
<html>
Try here <A
HREF="http://webhome.idirect.com/~wrayt/rebma ... me.idirect.
com/~wrayt/rebman.html</A> and go just past
elevator figure 2 to step 6.&nbsp; ...basically wrap a piece of paper,
<p>"Snader, Douglas E." wrote:
<blockquote TYPE=CITE>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; I have one more question
<br>torque tubes for drilling the eight evenly spaced holes?
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs
p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
Doug Snader
<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp
;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&
nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp
"Elite # 582"
<br>*----------------------------------------------------------------------
<br>&nbsp;The Murphy Rebel Builders List is for the discussion
<br>&nbsp;between builders and owners of Murphy Rebel aircraft.
<br>&nbsp;Archives located at:
<br>&nbsp;<a
href="http://www.dcsol.com/murphy-rebel/lists ... /www.dcsol.
com/murphy-rebel/lists/default.htm</a>
-------------*</blockquote>
<p>--
<br>Wray Thompson ...Rebel 306 ...home page <A
HREF="http://webhome.idirect.com/~wrayt/">htt ... ~wrayt/</A>
<br>My ICQ number is 29764664
<br>&nbsp;</html>
Wray Thompson
Is this any better Bob?
mark the
Doug Snader
"Elite #
582"
Joel Jacobs
Post by Joel Jacobs » Fri Feb 17, 2012 5:56 pm
To: <murphy-rebel@dscol.com>
Sent: Monday, May 29, 2000 11:34 PM
Subject: drilling holes in a tube
Cut a strip of paper maybe 1/2" wide - exactly long enough to wrap around
the tube so the ends meet. Fold the strip in half. Fold it again. Fold it
one more time. Unfold the strip and mark the creases to make it easier to
see them. Wrap the strip back around the tube and mark the tube.
Joel
Wonderful !! Thanks Wray !! Glad you could help those of us
not impaired by MicroShaft ... ;-)
-------------------------------orig.-------------------------------------
mark the
Doug Snader
"Elite #
582"
LisaFly99
WRAY
I don't know what you did to help BOB out, but it SURE did help on this end!
You're letters before where so saturated with HTML or what ever, they where
difficult to read at times. THANKS AGAIN.
Eric Fogelin
Post by Eric Fogelin » Fri Feb 17, 2012 5:56 pm
HTML has nothing to do with MicroShaft. It's not even
the new wave. Used for years years on Mac, Unix, Linux
and all those other great systems.....even Windows.
P.S. Wray, your web site is awesome. I don't know
if these web and email impaired folks have problems
with your excellent, detailed cad drawings, but I've
been to your site many times and have found it very,
very valuable. Thanks for what must be a great
effort on your part.
Sent: Wednesday, June 14, 2000 10:53 AM
Subject: Re: drilling holes in a tube
Wray Thompson
Sorry guys I didn't realize you weren't seeing it as I was ...looks the same to me
either way, but in Bobs reply I could see the html codes so turned them off.
LisaFly99@aol.com wrote:
WRAY
I know it's not new - it's just a DEFAULT setting in most of
MicroShaft's junk ! And VERY annoying !!
....bobp
----------------------------------orig.-------------------------------
