[rebel-builders] Outback tailwheel option on the moose
Posted: Sun Feb 19, 2012 12:04 pm
Thank you much...
Rick : )
Rick : )
floor,From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Subject: [rebel-builders] Outback tailwheel option on the moose
Date: Tue, 24 Apr 2007 18:50:49 -0400
Just to give it a proper subject title for searching...and to also state
that is the tire for the 1800 amphib main gear.
Sent: Tuesday, April 24, 2007 6:31 PM
Subject: RE: [rebel-builders] inner floor
RickHi Rick,
The outback tailwheel for the Moose is 11X 4 X 5
Nan
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf OfJohnson
Sent: Tuesday, April 24, 2007 3:28 PM
Subject: Re: [rebel-builders] inner floor
What is the tire size for the outback tailwheel option on the moose?
Rick
Date: Tue, 24 Apr 2007 17:39:35 -0400
That is how I do it as well Jean! Pick a starting point and measure for
channel locations. Mark them out and start drilling.
Sent: Tuesday, April 24, 2007 3:15 PM
either channels. instead
sheet
are different (3 pieces vs 1 piece), the inner floor is longer at
the cabin front, and there is a angle (inner always shorter than
outer), could I use the "hole matching technic" or it is better to
use the "lexan one"?
p.s.: french to english translation have been difficult.
Jean
Rebel 747R
Jean Poirier
Pr
