Outback tailwheel option on the moose
Posted: Sun Feb 19, 2012 12:04 pm
Just to give it a proper subject title for searching...and to also state
that is the tire for the 1800 amphib main gear.
Sent: Tuesday, April 24, 2007 6:31 PM
Subject: RE: [rebel-builders] inner floor
floor,Hi Rick,
The outback tailwheel for the Moose is 11X 4 X 5
Nan
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rick
Johnson
Sent: Tuesday, April 24, 2007 3:28 PM
Subject: Re: [rebel-builders] inner floor
What is the tire size for the outback tailwheel option on the moose?
Rick
Date: Tue, 24 Apr 2007 17:39:35 -0400
That is how I do it as well Jean! Pick a starting point and measure for
channel locations. Mark them out and start drilling.
Sent: Tuesday, April 24, 2007 3:15 PM
eitherHi Jean: I would be surprised if a "matching" technique worked forchannels.floor area due to the fact of the varying angles of the variousinsteadThe lexan sounds like a pretty accurate method. My own method was
simply to start with 4 corner holes with floor in place - remove the
floor panel - connect the holes, measure and transfer centerlines. I
have done this method
3 times now with great success. Bob J Rebel 652,725,192/731
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Tuesday, April 24, 2007 2:44 PM
Subject: [rebel-builders] inner floor
sheet
are different (3 pieces vs 1 piece), the inner floor is longer at
the cabin front, and there is a angle (inner always shorter than
outer), could I use the "hole matching technic" or it is better to
use the "lexan one"?
p.s.: french to english translation have been difficult.
Jean
Rebel 747R
Jean Poirier
Pr
