[rebel-builders] Elite flying
Post by Wayne G. O'Shea » Sun Feb 19, 2012 3:00 pm
Be like driving a jeep without the doors on Mike....anything not bolted down
is going out!
Sent: Monday, March 26, 2007 10:20 PM
Subject: [rebel-builders] Elite flying
10 hours in. I have to finally admit after all the hype this group gives
about the flying characteristics of the Murphy planes that I been reading
for the last couple years, I was always a skeptic. But today I will say
you are all correct. My airplane has been handling great, lands nice,
takes off like a rocket. I couldn't be happier. I am almost certain this
Elite will out perform the Husky.
I am getting close to warm weather and want to remove the doors for a
little more excitement. Is there any concerns doing this as far as
handling goes? Do I need to tie down anything under 25# in the cockpit?
So far the MAM fiberglass cowl has been ok with the stock inlets. Warmest
day yet here at 74F and yet to see a CHT over 400, cruise is normally 325.
Mike Betti
Post by Bob Patterson » Sun Feb 19, 2012 3:00 pm
Hi Mike !
Glad you are having fun !! I have no doubt it will beat
a Husky ! :-)
You can try opening a window (or 2) first - that usually
opens things up enough for most folks !! Should be no
handling issues, but your maps will be gone !
They say that, on the Breezy, the seat gets 2" narrower
for every 500 ft. you go up - likely the same feeling without
the doors ! ;-)
http://www.prosumers.ca
about the flying characteristics of the Murphy planes that I been reading for
the last couple years, I was always a skeptic. But today I will say you are
all correct. My airplane has been handling great, lands nice, takes off like
a rocket. I couldn't be happier. I am almost certain this Elite will out
perform the Husky.
I am getting close to warm weather and want to remove the doors for a little
more excitement. Is there any concerns doing this as far as handling goes? Do
Mike Betti
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 3:00 pm
Mike:
Presumably, you narrowed the spades to 4". I wonder if you also rounded the
tips? Anyway, next time you're up, try flying along with no pitch input,
then nudge the stick forward, and let the airplane recover. How quickly
does it come back to the trimmed attitude? In my case, while it isn't
something you notice immediately, the answer is "a lot slower than any
production airplane I've ever flown - maybe 10 or 15 seconds". Now, I'm on
amphibs, so there's a lot more inertia involved.
Personally, if I was doing it again, I'd remove the 4" from the inboard edge
of the spades, and lengthen the stab to fill the gap, bit that is
structurally a bit more complicated. Better still, I'd keep the spades at
8", but shorten them by a third, and increase the mass balance, but I'd like
to speak to somebody who understood the aerodynamics a bit better before
trying that. Anybody know such a person?
The other question I'm waiting for you to answer is "where is your elevator
in level flight?" I'm contemplating another 1/16" under the rear stab
attach fitting at the next annual.
Al
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 3:00 pm
Al,
You should of gotten my answer last week about the elevator. Anyway, it is
perfectly level in cruise flight.
I did narrow the spades and rounded them too. I never tried the recovery
from pitch you mention, but I will try it and report.
Sent: Tuesday, March 27, 2007 6:32 AM
Subject: RE: [rebel-builders] Elite flying
Mike:
on
edge
like
elevator
Al
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 3:04 pm
Hi all,
The group has been pretty quiet lately so I thought I would share some more
flight experience in my Elite.
I don't notice any difference with pitch stability with the flaps pulled to
1 notch. Not too crazy experimenting with the flaps while in cruise, but
from what I can tell there is no difference. There is some stability but it
is very mild as Al points out. I am surprised though that I can fly hands
off in smooth air almost endless. It seems there is some slow oscillation
taking place if you really study the VSI close. But if you push the stick
forward 1/8" its going to crash or pull the wings off anyway.
I also tried checking max operating ceiling. I made it to 14,000' and
decided to retest this at a later date with some O2 and a parka! I was at
1500# gross and still maintained 1000' per minute at 14000. Not sure when it
is going to give up.
Did some takes offs to check ground runs. At a std day, 1500#, I get 320'
ground roll with 1 notch flap. I get 250' ground roll with full flaps.
Pretty impressive.
The airplane is quite impressive on wheels. Other than the crosswind almost
putting me into the runway lights yesterday, it has been going well. The
airplane is definitely light on its gear during roll and proper aileron
input is necessary to stay on the center line. Going to take a little more
time to master. Hopefully I don't learn the hard way.
Mike Betti
N771ME
Sent: Monday, April 02, 2007 12:30 PM
Subject: RE: [rebel-builders] Elite flying....Al H.
Mike,
Since you don't need to re-trim between cruise and landing configurations
does indicate your aircraft is near zero w/r/t pitch stability ... goes
where you put it ... regardless of airspeed.
Big goose egg this week on the project ... we're in Libby visiting the
home
front. But when I do get to flying it, like you, I'll be sharing initial
flight reports.
Bob 612e
michael betti
Sent: Monday, April 02, 2007 9:54 AM
There isn't really much for feed back from the stick. and really have
no need for trim. I don't use the trim at all. It flys at cruise hands
off, and during landing the change isn't that I need to retrim.
Looking forward to hear about your test flights.
Date: 04/02/2007 7:14
Subj: RE: [rebel-builders] Elite flying....Al H.
Mike,
Flew an RV4 two weekends ago. It recovers nicely from pitch-down
nudges at
varying speeds. Also, an increase in airspeed, for a given pitch trim
setting, does require resetting pitch trim to remove the new pitch up
tendency. So I would say this RV4 anyway does not display similar
Elite
pitch behavior.
Having made the elevator tip mods as you and others have, I'm now
thinking
(in hind sight) I should have done it like you recently mentioned -
cut
down the elevator spades on the inside, followed by stab build up to
fill
the gap. This would have increased the stab area (retaining the
originally
designed tail area), while also decreasing the elevator's "power
steering".
Doing the mod the way I (and others) seems to remove the elevator's
return-to-neutral condition, but at the same time reduces the overall
tail
area (stab and elevator combination); which doesn't help the pitch
stability issue. With the Elite, I think the stab area plays as big
role
as the elevator tips do ... perhaps even more ... my two cents ...
never
actually flown one ... so my words here are speculative at best.
My modified elevator tips measure 3-1/4" wide. This is a 3/4" more
cut per
tip then Al's or Mike's 4" wide tips. In doing so, I also have
reduced the
over-all width of the tail feathers by 1-1/2" more then Al's or
Mike's. If
612e is pitch divergent, then I'd have to say the "main" problem is
not the
elevator tips, but a marginal stab area. Not too much longer and I'll
have
the answer to this one.
From what I've read, I'm thinking the Elite's pitch stability must be
pretty close to zero across most of its CG range. Where a slightly
positive value indicates a return to original condition after a nudge,
slightly negative value indicates divergence - continued pitch
acceleration
in the same direction as the nudge, and a zero value indicates the
aircraft
stays were you put it - with no tendency to change on its own. There
is an
aft C.G. value that will create a zero pitch stability condition, and
this
should be at the aft C.G. of the working flight envelope ... or just
fwd of
that value. Question is, for the Elite, how do we get that neutral
point
C.G. aft of the working flight envelope.
At a given airspeed trimmed for pitch hands off condition, if an
increase
in airspeed creates a requirement to add nose down pitch, the aircraft
must
be on the positive side of the neutral (or zero) pitch stability
value,
which means it will eventually return to the original flight condition
even if you may not live long enough to see it happen. I would think
this
would be after the new airspeed stabilizes ... not during the
acceleration
phase of getting to that new airspeed.
I might have missed it in this thread, but Mike, do you experience the
need
to increase pitch down trim after increasing the airspeed?
Anyway, my speculation is that the stab on the Elite may well be too
small
... and modifying the elevator tips as Mike mentioned earlier may well
be
the best fix ... that is, for those who haven't already cut down the
elevator horns as we all have done to date. For those (like me) who
have
... well that's a topic for another day.
Cheers, Bob 612e
Mike Betti
Sent: Saturday, March 31, 2007 9:15 AM
Subject: Re: [rebel-builders] Elite flying....Al H.
The control surfaces have the 5 degree angle built in them. At 0 flap
setting, I set up the bottom of the forward surface to be level with
wing. That puts the trailing edge of the control surface in 5 degrees
reflex. Where is it ends up on the cabin doesn't matter at that point.
I am not too concerned about this characteristic, just not a good
plane to
fall a sleep in :(
I think the RV's have a simular situation. Might be a good question to
that
group.
Al, CG is at 11.92 aft empty.
Sent: Saturday, March 31, 2007 9:51 AM
Hi Mike !
The pictures on your site show the flap/fuselage box
well below the top of the fuselage - that's why I thought
that was the 'zero' position. If you DO go negative
from there, the box will still be at the lower position.
The reason I think it will affect handling is that a
big part of the handling/stability issue with the Elite
comes from the powerful vortex that comes off the
flaps - particularly the ends. That's why I was
wondering if an outboard end spill plate might help ...
and maybe an inboard one, as well.
Perhaps you could try Al's 'pulse test' with different
flap positions - might improve things a bit - especially
negative... The Elite was designed to cruise with the
built-in negative (about 5 degrees) from having the box
even with the top of the fuse.
With the mods you have done, reducing the width of
the horns, and rounding the leading edges, it will be
MUCH better than the original ! As Al said - "It
certainly got your attention !" :-)
On Saturday 31 March 2007 12:07, Mike Betti wrote:
Bob,
I have the negative flaps and ailerons.
Sent: Friday, March 30, 2007 10:33 PM
cojones to
measured
very
By
why I
don't
mail2web.com
Roger Cole
Post by Roger Cole » Sun Feb 19, 2012 3:04 pm
Hi Mike,
I have been watching your progress with much interest. You are way
ahead of me since I am just starting the second wing. The issue of
pitch stability is a concern. Does fore or aft weight distribution
affect pitch stability?
BTW, where are you located? If possible, I would like to see your
Elite.
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
On Apr 15, 2007, at 8:10 PM, Mike Betti wrote:
Hi all,
some more
pulled to
cruise, but
stability but it
hands
oscillation
stick
was at
sure when it
get 320'
Pretty impressive.
crosswind almost
well. The
aileron
little more
Mike Betti
N771ME
Mike,
configurations
goes
home
initial
flight reports.
Bob 612e
michael betti
hands
Mike,
nudges at
trim
Elite
pitch behavior.
thinking
cut
fill
originally
steering".
tail
role
never
cut per
reduced the
Mike's. If
not the
I'll
have
nudge,
acceleration
aircraft
is an
this
fwd of
point
increase
aircraft
must
value,
condition
this
acceleration
need
small
well
be
have
Cheers, Bob 612e
Mike Betti
point.
plane to
fall a sleep in :(
question to
that
group.
Hi Mike !
cojones to
measured
very
By
why I
don't
mail2web.com
N.Smith
Post by N.Smith » Sun Feb 19, 2012 3:04 pm
Hi Mike
Thanks for posting all the reports, all very interesting and I'm following
them closely.
Working on the second wing here, then when that's finished - rig them to the
fus and finish off the wiring, then probably mount the floats, then
hopefully not too long for my engine to be available !
Thanks again
Nig
745E
Mike Betti
Sent: 16 April 2007 02:11
Hi all,
Pretty impressive.
Mike Betti
N771ME
Mike,
home
flight reports.
Bob 612e
michael betti
Mike,
nudges at
Elite
pitch behavior.
thinking
cut
fill
originally
steering".
tail
role
never
cut per
reduced the
Mike's. If
not the
have
acceleration
aircraft
is an
this
fwd of
point
increase
must
value,
this
acceleration
need
small
be
have
Cheers, Bob 612e
Mike Betti
plane to
fall a sleep in :(
that
group.
Hi Mike !
Bob,
cojones to
measured
very
By
why I
don't
mail2web.com
michael betti
Post by michael betti » Sun Feb 19, 2012 3:04 pm
Roger,
Sorry, I haven't experimented with weight yet. I am based at Iron
Moutain, MI., just 150 miles north of OSH.
Date: 04/15/2007 21:41
Subj: Re: [rebel-builders] Elite flying
Hi Mike,
Elite.
Roger Cole
Murphy Elite #709
Hi all,
some more
pulled to
cruise, but
stability but it
fly
hands
oscillation
stick
was at
sure when it
get 320'
flaps.
Pretty impressive.
crosswind almost
well. The
aileron
little more
Mike Betti
N771ME
Mike,
configurations
goes
visiting
home
initial
flight reports.
Bob 612e
Of
michael betti
have
hands
Mike,
nudges at
trim
up
Elite
pitch behavior.
thinking
cut
fill
originally
steering".
overall
tail
big
role
never
cut per
reduced the
Mike's. If
not the
I'll
have
be
nudge,
acceleration
aircraft
There
is an
this
just
fwd of
point
increase
aircraft
must
value,
condition
think
this
acceleration
experience
need
too
small
well
be
who
have
Cheers, Bob 612e
Of
Mike Betti
flap
with
degrees
point.
plane to
fall a sleep in :(
question to
that
group.
Hi Mike !
cojones to
before
measured
very
By
why I
don't
mail2web.com Â- What can On Demand Business Solutions do for you?
http://link.mail2web.com/Business/SharePoint
Roger Cole
Hi Mike,
I live in a Chicago suburb, but I have to be in Houghton, MI, for a
daughter's wedding on June 1. I expect to pass through Iron Mountain
2 or 3 days before that date.
Roger Cole
Murphy Elite #709
On Apr 16, 2007, at 9:26 PM, michael betti wrote:
Roger,
Hi Mike,
Elite.
Roger Cole
Murphy Elite #709
Hi all,
some more
pulled to
cruise, but
stability but it
fly
hands
oscillation
stick
was at
sure when it
get 320'
flaps.
Pretty impressive.
crosswind almost
well. The
aileron
little more
Mike Betti
N771ME
Mike,
configurations
goes
visiting
home
initial
flight reports.
Bob 612e
Of
michael betti
have
hands
Mike,
nudges at
trim
up
Elite
pitch behavior.
thinking
cut
fill
originally
steering".
overall
tail
big
role
never
cut per
reduced the
Mike's. If
not the
I'll
have
be
nudge,
acceleration
aircraft
There
is an
this
just
fwd of
point
increase
aircraft
must
value,
condition
think
this
acceleration
experience
need
too
small
well
be
who
have
Cheers, Bob 612e
Of
Mike Betti
flap
with
degrees
point.
plane to
fall a sleep in :(
question to
that
group.
cojones to
before
I of measured very By why I don't
mail2web.com
Mike Betti
I should be around, let me know when you are coming.
Sent: Tuesday, April 17, 2007 8:47 PM
Hi Mike,
Roger Cole
Murphy Elite #709
Roger,
Hi Mike,
Elite.
Roger Cole
Murphy Elite #709
Hi all,
some more
pulled to
cruise, but
stability but it
fly
hands
oscillation
stick
was at
sure when it
get 320'
flaps.
Pretty impressive.
crosswind almost
well. The
aileron
little more
Mike Betti
N771ME
visiting
Of
have
up
overall
big
be
There
just
think
experience
too
who
Of
flap
with
degrees
before
mail2web.com
