[rebel-builders] Elite Elevator Mods
Posted: Sun Feb 19, 2012 3:00 pm
by Robert Johnson
Hi Bob: Nice to see someone else getting rid of the "square" ends on the
tips. We have done the same thing to the elevators and rudder of the Moose
we are constructing. I have not had any experience with an Elite, but your
elevator horn beef up sure looks like the 3500 Moose construction.Nice work.
Bob J
Sent: Sunday, March 25, 2007 11:55 PM
Subject: [rebel-builders] Elite Elevator Mods
Greetings Elite builders,
For those who haven't done it yet, I uploaded a two pics of the elevator
tip
mod and one of the horn mod (heavy duty version). Have more I can upload
if
anyone wants to see them.
Bob 612e
www.aacnet.com/elite
by Robert Andrews
Thanks Bob.
The elevator tip is as solid as can be, but somehow in its construction I
got an ever so slight twist in it. I'm debating whether or not to re-do it
or make the one on the other side have an equal twist in the other
direction. I discovered it looking straight on ... almost undetectable
veiwing from the side ... decisions decisions ... hmmmm. Could be a feature
that ends up improving performance ... ya think? (hehehe).
Bob 612e
Robert Johnson
Sent: Monday, March 26, 2007 5:09 AM
Subject: Re: [rebel-builders] Elite Elevator Mods
Bob J
tip
if
Bob 612e
by Mike Betti
I guess I would mount it to the stab and see if there is a clearance issue
with it first.
Sent: Monday, March 26, 2007 11:21 PM
Subject: RE: [rebel-builders] Elite Elevator Mods
Thanks Bob.
it
feature
Bob 612e
Robert Johnson
work.
Bob J
tip
if
Bob 612e
by Robert Johnson
Hello again: Sorry, can't comment on the twist issue without a visual. -
your call on that one. Bob J
Sent: Tuesday, March 27, 2007 12:21 AM
Thanks Bob.
it
feature
by Robert Andrews
Bob,
Here's a link to some pics of my "twisted tip". Although I seriously think
it will have little impact on the flight characteristics ... provided the
other side becomes the exact inverse of this one, I've decided to re-do it.
Will be a simple matter of popping off the skin, and putting on a new one
... squared up correctly this time.
www.aacnet.com/elite/tip
The new elevator tip width is a bit thinner then Al's 4" ... mine are 3.25"
wide. With the side plate adding to the vertical strength, plus the way the
0.025 top and bottom skin reaches back across the main elevator, it's very
solid laterally as well.
Bob 612e
Robert Johnson
Sent: Tuesday, March 27, 2007 4:57 AM
Thanks Bob.
it
feature
by Robert Andrews
Hi Mike,
Clearance is ok ... actually, I did all the tip work with the elevator
mounted to the stab. Which makes for no accetable excuss as to how I got
that twist in the tip ... except I guess I could blame the barometric
pressure (hehehe). Oh well ... no biggie ... its only metal and time right?
I'm hanging on every word you type w/r/t to your initial flight reports ...
thanks for posting them !!
Bob 612e
Mike Betti
Sent: Tuesday, March 27, 2007 4:12 AM
with it first.
Thanks Bob.
it
feature
Bob 612e
Robert Johnson
work.
Bob J
tip
if
Bob 612e
by Robert Andrews
Building the second tip - there'll be no twist in this one. Amazing what a
clamp and a few pieces of angle stock (on both sides) can do. Now, to get
some more 0.025 to re-do that other tip ... and another task along the way
to weight-off-wheels will be done ... :-)
www.aacnet.com/elite/no-twist.jpg
Bob 612e
Robert Andrews
Sent: Monday, March 26, 2007 9:22 PM
Thanks Bob.
Bob 612e
Robert Johnson
Bob J
tip
if
Bob 612e
Before you get too far into redoing the other tip...
When I inherited a Moose project the elevator spades had a good twist in
them. I found that by retaining one side at it's original #30 and twisting
the spade straight... that the holes on the other side were only misaligned
by the the amount necessary to drill them up to a 5/32 rivet. Drilled a
couple fresh holes to hold it straight and then brought the old holes up to
5/32 and riveted... cured the twist.
Sent: Wednesday, March 28, 2007 9:28 AM
Bob 612e
Robert Andrews
Thanks Bob.
it
feature
Bob 612e
Robert Johnson
work.
Bob J
tip
if
Bob 612e
by Robert Andrews
Thanks Wayne ... good idea.
Bob
Sent: Wednesday, March 28, 2007 9:09 AM
Bob 612e
Robert Andrews
Thanks Bob.
it
feature
Bob 612e
Robert Johnson
work.
Bob J
tip
if
Bob 612e
Posted: Sun Feb 19, 2012 8:58 pm
by flex
-------- Forwarded Message ---------
Original: DATE..... 3/28/2007 9:26 AM
Original: FROM..... robert@montanasky.us
