chromating
chromating
Post by Mike Davis » Fri Feb 17, 2012 4:21 pm
Received: from MMoreho699@aol.com
by imo17.mx.aol.com (IMOv14.1) id GJYSa06445
for <murphy-rebel@dcsol.com>; Fri, 17 Apr 1998 14:46:36 -0400 (EDT)
Message-ID: <6fda7a2e.3537a38f@aol.com>
Date: Fri, 17 Apr 1998 14:46:36 EDT
Mime-Version: 1.0
Subject: chromating
X-Mailer: AOL 3.0 for Mac sub 65
Hi!
I know the AN nuts, bolts, washers, etc. are plated so they don't need to be
chromated. How about the aluminum parts that interface with them? And how
about the stainless steel rivets? A man once remarked to me that 'stainless'
ought to be two words, 'stain less', i.e. they still corrode but not as
quickly.
Thank you for your support,
Dan
chromating
Received: from tim - 153.35.236.230 by email.msn.com with Microsoft SMTPSVC;
Fri, 17 Apr 1998 15:37:24 -0700
Received: by localhost with Microsoft MAPI; Fri, 17 Apr 1998 15:34:32 -0700
Message-ID: <01BD6A16.518A8820.tlcarter@email.msn.com>
Reply-To: "tlcarter@msn.com" <tlcarter@msn.com>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: RE: chromating
Date: Fri, 17 Apr 1998 15:33:32 -0700
X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
MIME-Version: 1.0
Return-Path: tlcarter@email.msn.com
Dan:
In a previous message I referenced LPS spray. It is a corrosion inhibitor
that is superior in many ways to WD40. Lot's of A&P's use it religiously.
My A&P uses it for the purpose that you are asking about. Whenever there
is contact with a CAD plated bolt to other metal, the CAD will usually
scrape off, either during the installation or over time thru normal wear.
Just disassemble some of your stuff that has not even been in flight yet
and you'll see what I mean.
In those areas you mention, bolts, etc... Use a little (very little) LPS,
only AFTER you are torqued up.
Stainless rivets will probably not corrode in your lifetime, unless you are
planning heavy salt water operations.
Tim
Reply To: murphy-rebel@dcsol.com
Sent: Friday, April 17, 1998 11:46 AM
Subject: chromating
Hi!
be
'stainless'
quickly.
Dan
chromating
by imo23.mx.aol.com (IMOv14.1) id 8SQEa06270;
Sat, 18 Apr 1998 12:06:37 -0400 (EDT)
Message-ID: <77b11e80.3538cf8e@aol.com>
Date: Sat, 18 Apr 1998 12:06:37 EDT
To: tlcarter@email.msn.com, murphy-rebel@dcsol.com
Mime-Version: 1.0
Subject: Re: RE: chromating
Thanks Tim!
I have noticed that the cadmium layer has worn off when putting on and
taking
off nuts. I guess I'll look for this 'LPS' spray in my catalogs.
Take care,
Dan
