reply to Brian
Posted: Fri Feb 17, 2012 5:47 pm
Hi Brian, yeah it reads a little funny, but that is exactly what I am
suggesting. There cannot be any other way you can have aileron use in flight
AND be able to do what he is apparently capable of doing. Those plugs as you
correctly call them are a very tight or press fit into the tube, I SUPPOSE
that you could have one or two that were not rivetted AS THEY ARE SUPPOSED
TO BE OF COURSE and precisely because of the press fit and therefore the
friction of the plug inside the tube, you could get the tube to move, read
rotate. If I am recalling right, there are six of those plugs with control
arms attached, three different lengths of torque tube and two plugs of
course per tube. Now you have been inside these aircraft a lot more than
most of us, maybe you can come up with another theory, exactly the reason I
put it out there. OK? Needless to say, as he flies a little more,
the plug(s) will "wear" away some of the friction and we are looking at a
very bad situation. Regards, Geert
