The end.....of Spar ends
Hibbs
Post by Hibbs » Fri Feb 17, 2012 5:47 pm
Thanks everyone for the responses both here and privately. To sum up
from everyone: It does not matter much as long as I am
careful/consistent when it comes time to skin the wing. Back to work
for me.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Post by Bob Patterson » Fri Feb 17, 2012 5:47 pm
Welllllll.... It seems that 12.25 is the correct distance, and
all 3 spars should be the same, ON THE ROOT END. The extra 1/4" can
hang out on the TIP end without causing problems.
If you put the extra 1/4" on the root end, the skin might
end up short on the root end (VERY messy !!!). =====
-------------------------------orig.-------------------------------------
for me.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Warren T. Montgomery
Post by Warren T. Montgomery » Fri Feb 17, 2012 5:47 pm
Bob, isn't that what a stretcher is for ;-)
Closing wing and last flap today. Yeesss!
Welllllll....
end up short on the root end (VERY messy !!!). .....bobp
Good Stuff !!! Keep going - it won't be long now !!! :-)
--------------------------------orig.-------------------------------------
Welllllll....
