Posting this message for Gil Tessier about his Elite that is nearing
completion. He has an engine driven fuel pump but has no back up or boost
pump in the works for his project. What has been the norm for this type of
system? I would imagine that a back up pump to the side with a one way
valve installed on the main fuel line would be mandatory from an inspectors
view?
Steve W 637R
RealLiveMoms: Share your experience with Real Live Moms just like you
http://www.reallivemoms.ca/
[rebel-builders] 0-360 boost pump
It is in Canada at least. If you have one pump..must have two. Pros and Cons
to both arrangements..series or parrallel... with both being acceptable
installs.
That said...if his fuel lines are run properly...rearward from the tank
outlet, down the rear window area and forward after that for a proper
gravity feed run......I'd be removing the fuel pump, putting a plate over
the mounting boss and running gravity feed to KISS.
Sent: Monday, March 05, 2007 3:01 PM
Subject: RE: [rebel-builders] 0-360 boost pump
installs.
inspectors
view?
Steve W 637R
Thanks Wayne
I'm not sure what size pipe/hose assemblies were provided with his kit but
I'm thinking that it is 1/4" inside diameter. May be a fuel flow test with
what he has minus the pump would be the thing to do. I believe that the
lines are routed properly for the best gravity flow. That answers the
question!
Steve
Buy what you want when you want it on Sympatico / MSN Shopping
http://shopping.sympatico.msn.ca/conten ... ata=081805
question!
Steve
_________________________________________________________________From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Subject: Re: [rebel-builders] 0-360 boost pump
Date: Mon, 5 Mar 2007 15:09:55 -0500
Cons
installs.
boostPosting this message for Gil Tessier about his Elite that is nearing
completion. He has an engine driven fuel pump but has no back up orofpump in the works for his project. What has been the norm for this typesystem? I would imagine that a back up pump to the side with a one way
inspectors
view?
Steve W 637R
He should have 3/8 lines. If so and he ran a good route he'll have good
flow.
Sent: Monday, March 05, 2007 3:19 PM
flow.
Thanks Wayne
with
question!
Steve
Cons
installs.
inspectors
view?
Steve W 637R
