FWIW Rick
I run MAM's solid tailwheel with no damping in the pivot.
2 leaf steel spring
pivot angle is vertical without the plane loaded and it tilts very
slightly (top of pivot forward) when at gross weight.
I have never (knock on wood...) had a hint of shimmy so far as I come up
to 60 hours and about 160 landings
steering springs are screen door compression type and they are slightly
loose
Don't forget that a badly out of balance wheel will shimmy no matter
what you do....
A scalloped tire wouldn't help either.
[rebel-builders] Bloody Rotten Tailwheel Shimy !!! :o(
Hi Rick !
I went through this a few years ago with our Scott 3200 - I did
find an exploded view of the whole assembly somewhere on the net ...
it could be that your damping washers are badly worn & need
replacement .... 45 - 50 lb. pressure sounds about right.
If you put a foot on top of the tire & push down, you should
get just a small bulge at the bottom - enough to show that
the tire is 'giving' a bit - for cushioning.
Tightening that big nut on the bottom should do it. Many say
the pivot bolt should be vertical - our is, or slightly tilted rearward
at the bottom when really loaded.
Scott were very specific that you MUST use their TENSION
springs, (NOT compression springs) and there must be NO
slack in the chains. Ours have a very little bit of slack ...
maybe less that 1/4" sag ...
Tightening the nut solved the shimmy - so maybe you have
something worn out in there. Also ... avoid too much grease !
Personally, I avoid steel springs - years of bad experiences !
Maybe 2 leaves wouldn't bounce so much, and might let the
pivot get to vertical.
http://www.prosumers.ca
On Sunday 25 February 2007 23:54, Rick Harper wrote:
tailwheel setups :
pivot) ... (I need to know whether your pin is dead vertical, leaning
forward at the top (and how many degrees if so ? .......... ) or leaning
backwards at the top (and how many degrees if so ? .... )
HAVE "some girl builders" ?!?) .... to tell me a few HOW & WHYS with YOURG'day All ....
H...E....L....P..... !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The plane is going GREAT again !!!
BUT .........................................
The tailwheel is driving me NUTS - with shimmy :o(
Please note :
I currently have about 50ish Lbs PSI in the tyre ...
The pivot bolt is angled BACKWARDS by about 10 degrees at the top
AND ... it is done up about as tight as I dare do it !
(but - there is little or no damping / friction within the pivoting motion)
My connecting springs & chains are "loosish"
I have different spring strengths on either side
I have a 2" wide , 3 leaf STEEL tailspring
Could I possibly get you guys 'n' gals (I assume here that we DO actually
tailwheel setups :
at ? ...........................................( BTW - I am running a SCOTT 3400 tailwheel - 10" dia' pneumatic tyre)
1) What Tyre pressure do you use ? ....................
2) What angle is the pivot pin for the yoke
the body of the Tailwheel assembly - around which the yoke & wheel... (this is the vertical axis pin / bolt, that holds the wheel yoke to
they ? ...................................... )3) Do you have the connecting springs & chains to the rudder arms
TIGHT or LOOSE ? ............................................
(if they are LOOSE - the HOW loose are
side ? ...............................4) Do you use different spring strengths on either
there ? ...................................(if so, what sort of difference in strength is
for ? ......5) ANY other tips or points of interest that I should be looking out
Many Thanks Everyone !
Rick "Biggus" Harper
541R "Flying again"
Hi Rick is it possible that your tire has developed a flat spot after not
moving for several months with low pressure?
At 10:54 AM 2/26/2007 +1100, you wrote:
YOUR tailwheel setups :
leaning forward at the top (and how many degrees if so ?
.......... ) or leaning backwards at the top (and how many degrees
if so ? .... )
HAVE "some girl builders" ?!?) .... to tell me a few HOW & WHYS withG'day All ....
Please note :
2) What angle is the pivot pin for the yoke at ?
if so ? .... )
(if they are LOOSE - the HOW loose are they ?
...............................4) Do you use different spring strengths on either side ?
...................................(if so, what sort of difference in strength is there ?
? ......5) ANY other tips or points of interest that I should be looking out for
DrewMany Thanks Everyone !
541R "Flying again"
Rick Harper
Thanks Ken ..... I haven't checked the balance of the wheel as yet !
Biggus
Sent: Monday, February 26, 2007 11:56 AM
Subject: Re: [rebel-builders] Bloody Rotten Tailwheel Shimy !!! :o(
FWIW Rick
2 leaf steel spring
loose
what you do....
Biggus
FWIW Rick
2 leaf steel spring
loose
what you do....
Rick Harper
G'day Bob !
I replaced ALL the guts of the pivot mechanism when I rebuilt it .....
But I'll take it all apart & check those friction washers again ..
(I am guilty of regularly regreasing the pivot pin though ! :o(
I did NOT realise that SCOTT says to use tension spring either !
Biggus
Sent: Monday, February 26, 2007 12:38 PM
Hi Rick !
tailwheel setups :
Biggus
Hi Rick !
Please note :
tailwheel setups :
541R "Flying again"
Rick Harper
G'day Ken ....
Nope,... the tailwheel doesn't have any flat spots ... but I haven't checked it's balance as yet .... so That is now on my list !
Biggus
541R
Sent: Monday, February 26, 2007 2:11 PM
if so ? .... )
Biggus
541R
Please note :
if so ? .... )
541R "Flying again"
