[rebel-builders] wiring
Rickhm
Post by Rickhm » Sun Feb 19, 2012 11:52 am
They install fiber optic cable through up to 1 mile of pipe by simple blowing air through the pipe. I did this with wire through a 20' PVC pipe once and it workes great. Simply hook up the compresser to a push button jet and blow the line through! It doesn't matter if there is already wire in there!
Rick Muller SR70
As an add on to Jeans comment, a Shop Vac works well to pull that masking tape
ball through. Just be sure the available line is short enough so the shop Vac
doesn't eat it.
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 11:52 am
Hmmm, too bad that couldn't be used to feed through the 2 hydraulic lines and a brake line throught the front struts of the 1800 amphibs. Still remember doing that with mine, but it wasn't easy and took a lot of cussing before finally done. The biggest challenge was getting it around the attach fittings. Then I still remember, too, when I drilled a hole in my strut to attach the steps, I forgot about the lines inside, and sure enough, drilled right into one of the hydraulic lines. So I got some extra practice doing it all over again, and lots more cussing. Anyway, lots of joys building these machines, as you all are finding out.
Date: Tuesday, February 20, 2007 8:57 am
Subject: Re: [rebel-builders] wiring
Rick Muller SR70
that masking tape
the shop Vac
doesn't eat it.
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 5:54 pm
Ralph,
