[rebel-builders] Rebel - HEEEEeeeeeeeeeeeeeeelp ! (Airspeed Indicator)
Posted: Sun Feb 19, 2012 11:52 am
Bewdy .... Ta !
Sent: Tuesday, February 20, 2007 2:21 PM
Subject: Re: [rebel-builders] Rebel - HEEEEeeeeeeeeeeeeeeelp ! (Airspeed Indicator)
Hi Rick !
No problem going to 1/2" if you want - you do still have to
reduce to size of tubing to connect to the ASI at some point,
though.... :-)
As for static - just disconnect the tube at the back of the
ASI - that's what most of us end up doing ! :-)
http://www.prosumers.ca
On Tuesday 20 February 2007 03:00, Rick Harper wrote:
suggest ....
of course)
sorted out properly :o(
Hi Rick !
though.... :-)
(aircraft ) mate .... but I might remake the pitot tubes to 3/8" as youG'day Bob !
Yeah - I mentioned the "shuttlecock pitot" idea to my designer
suggest ....
even ?!?!?!?!?! ....... I can't think of any - other than a rain collector(do you reckon there would be any problem if I made 'em 1/2"
of course)
figure out the full advantage of the new cuffs & VG's until I get the ASII'll have a go at repositioning the static as well .....
It's just a pisser - after building & repairing all this time - now I can't
Indicator)Thanks for your thoughts though !!!
Biggus
541R
Sent: Tuesday, February 20, 2007 3:46 AM
her
Hi Rick !
Congrats on getting flying again !! Great, isn't it ?!!!
Welcome to the Rebel ! The ASI problem you have is
NORMAL !!!! Almost ALL Rebel ASI's tend to read low on the high
end, and high on the low end ..... most likely because of the
huge range of angles achievable.
One solution is to go to a much larger diameter pitot tube -
say 3/8" +. This gives a wider area for pressure, and a better
chance of closer readings. Best location is about 3-6" below
the wing, about 1/3 of the way back - plain tube mounted on the
inboard side of the strut, fastened to the wing by thin, wrap-around
straps worked for me on 2 Rebels.... Most just use cabin air
for static - it's VERY difficult to find a good position for source.
You could play around with the angle of mounting the
pitot tube - likely it's different now than original. The cuffs
will likely allow cruise at a more nose-down attitude - but
unfortunately, also allow a ridiculously high attitude for
landing ! Test aircraft have the end of the tube mounted
on a pivotting shuttle-cock, so it's always aligned to the
airflow !
On Monday 19 February 2007 05:09, Rick Harper wrote:G'day Everyone ....
Well ,..... it's been 18 (or19) months since I damaged her & pulled
99%apart ...... but .............docileVH - REB ( Rebel 541R ) now FLYS AGAIN Woo Woo !!!!!
(and the stall with my home made cuffs and VG's is REALLY benign &
---------------------------------------------------------------------------------------Now ...... I need your help people ....
My Airspeed Indicator was just checked (in situ') and is reading 98 -
theacurate over it's entire range - ( 20 to 160 knots ) ..... BUT ...When I test flew her - it consistantly read 12 ish Knots UNDER range in
aair at high speed ...... and at least 10 ish knots OVER as I was rounding
out to land ?!?!?(I did a bunch of flying on Saturday & Sunday - and, using the GPS over
themultitude of headings & altitudes - acertained that the cruise speed is
actually 100 knots - andleading edge of the port wing - by about 18" - and about 5 feet out fromI have BOTH the pitot and the static probe hanging off the front of the
rootsystem / inlet etc, etc .... ???My own suspicions are :
1) Problem with the static air side of the system - somewhere ?!?
2) False readings from the high angle of attack she now can achieve
3) pixie dust caught in my pitot tubes ... (just kidding)
Anyone got any suggestions about WHERE to / how to set up the staticThanks
Rick "Biggus" Harper
541R
( Airborne again
