ps to my previous
Charles Skorupa
ps to my previous
Post by Charles Skorupa » Fri Feb 17, 2012 5:46 pm
Great info, Geert. If I go to metal flaps, the flaps will have 3 supports:
one at each end and one in the middle of each flap. But the outboard end of
each flap will still be sharing the support bracket with the inboard support
for the aileron. I think that there is probably no way I can get away
without adding a counterbalance weight if I use metal flaps and fabric
ailerons and hook them together as flaperons. As I recall when visiting the
factory, when they determined how much counterweight to use they took a
metal aileron and then added enough weight to achieve a neutral balance.
They then removed a certain per cent of the counterbalance weight (20%??? I
can't remember??). At the least, I should add that amount of counterweight.
If I split the flaps and use fabric ailerons, no need for counterweights on
the aileron or the metal flaps. To reiterate, my primary reason for going
to metal flaps is to get some level of redundant support, although one could
argue that if the outboard aileron bracket failed, I would be faced with the
same potential problem since the fabric aileron has only 2 supports.
Basically, I hate the weight penalty associated with metal control surfaces
and especially the counterweight. I feel really stupid radiusing every
0.020 bracket, shaving all edge distances, adding 1 inch lightening holes to
save a zillionth of an ounce, only to add 5 lbs of counterweight dead
ballast! I keep coming back to the fact that the most efficient, sensitive,
but least redundant, design appears to be the original Rebel fabric
flaperons. The next best is split metal flaps with 3 flap support brackets
and fabric ailerons. The best for strength, safety, and longevity and the
worst for weight and sensitive control is the separate all metal flaps and
ailerons having 3 supports each and a counterweight like the Elite and the
Super Rebel use.
I have played with a design that uses double brackets at each hanger of
higher strength material to get redundancy. Another possible remedy is to
affix some sort of safety cable at each support bracket so if the bracket
parted company, the failure would not be catastrophic. There is just
something about the potential of a crack in that double-loaded, center
common flap/aileron bracket that seems like it could ruin your whole day.
At the very least, I would be thoroughly checking those brackets for cracks
at every preflight and more extensively during each annual. Can someone
save me from my paranoia?
- Chuck Skorupa -
To: "murphy archives" <murphy-rebel@dcsol.com>
Sent: Wednesday, May 10, 2000 2:27 PM
Subject: ps to my previous
PS I reread Charles Skorupa's question and I realized I had not addressed
it. Here is my very humble opinion: go very careful here, mixing metal
flaps
and fabric ailerons, unless there is no large difference in weight this
may
put some crazy stress on that center hinge. This time I would stick with
factory's opinion, if you can get them to give you one! After all I don't
think they ran that mix themselves or did they? My gutfeeling says, either
go all metal (AND BALANCE THE SURFACES) both ailerons and flaps or go all
fabric. Ok? Geert
Geert Frank
ps to my previous
Post by Geert Frank » Fri Feb 17, 2012 5:46 pm
it. Here is my very humble opinion: go very careful here, mixing metal flaps
and fabric ailerons, unless there is no large difference in weight this may
put some crazy stress on that center hinge. This time I would stick with the
fabric. Ok? Geert
ps to my previous
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:46 pm
Your following message has been delivered to the 153 members of
the list murphy-rebel@dcsol.com at 19:12:30 on 10 May 2000.
Chuck, I think you are getting a little "over worried" about the aileron
hinges breaking. Haven't seen a damaged hinge bracket yet and I've seen some
pretty mangled wings! Even a wing that was curved to about a 20 foot radius,
with outboard flaperon to match, had perfect hinge brackets!!!
I have metal flaperons on my Rebel (.016 thickness, same as SR2500), nicely
overlapped in the center to make one large surface and I wouldn't trade them
for the world.(although I do find the fabric covered Rebel lighter on the
controls!!!) That 8 pound weight hanging from each set, at the center hinge
bracket, that I keep knocking myself out on is another story!!!!! The
aluminum covering took the same time (within minutes) of fabric covering the
flaperons, to the Polyspray stage, on others I have done. Uses one full 4 X
12 sheet, cut in 1' x 6' pieces.
If you are having trouble sleeping at night over this problem, just pull out
a Zenair information package to read and it will put you to sleep!!!!
Blue skies,
Date: Wednesday, May 10, 2000 6:44 PM
Subject: Re: ps to my previous
support
counterweight.
could
sensitive,
Super Rebel use.
- Chuck Skorupa -
addressed
flaps
may
either
fabric. Ok? Geert
