[rebel-builders] Taxi test
Posted: Sun Feb 19, 2012 2:42 pm
Mike,
Most new brakes need a "wear-in" period to become effective, and are not
real effective at first. I taxied with brakes partially applied for first
few (slow) taxi tests on my SR. I also had back-filled the reservoir
(single reservoir for both brakes) and lines; no soft pedal and excellent
brakes. Taxi and ground steering is very easy and smooth with rudder alone,
and tail wheel kicks out with only slight brake application. My tail wheel
chains have practically no slack, with steering loads dampened by springs.
Don't know how much difference there might be between Elite brakes and SR
brakes, however.
Charlie Starr - SR N96CS
Sent: Saturday, February 10, 2007 3:24 PM
Subject: [rebel-builders] Taxi test
brakes, however.
Hi all,
Still waiting for my DAR to do inspection of N771ME Elite. He is coming
next saturday now. FAA dragged their feet with my paper work last couple
weeks, but all is a go now. Today only -10F but warmed up to 15F. I took
out my airplane to do some run ups and taxi testing for the first time to
get the feel of it. Good temps in this weather, 140 max oil with plugged
off cooler, and 300 max CHT no matter what I did on the ground.
Raised the tail at about 30mph down the runway, the airplane is a little
squirrelly but manageable, that is until I ground loop it. There was a 6
knot cross wind, which I really dodn't need at this stage of the game, but
ok.
I uploaded a picture in the files section, Elite, finished.....
Everything is checking out good except for the brakes. They are very poor
for some reason. The pedals are solid with not much movement of the
masters when applying them, so I don't think air is an issue. I did
pressure fill them from the bottom up through the bleeder. I tried
dragging them around the ramp, they got warm, but not much improvement.
During a run up I have a hard time holding the brakes over 1400 rpm. I did
manage a static full throttle, with 76X58 Sensenich prop, I got 2300. I
also don't have enough brake to kick out the tailwheel. I also run the
8.50 tires if that is any handicap.
Any thought?
Mike Betti
