tail lift
Geert Frank
tail lift
Post by Geert Frank » Fri Feb 17, 2012 5:46 pm
Hi, this is the second attempt to send this.Hi fellow sufferers! I reread
my instructions for tail lift device:
Pipe diameter I used is 1 5/16". I am sure that 1 1/2" will do fine also.
The three eyebolts are 3/8". Outer diameter of the eyes is 1 5/8", total
length each eyebolt is 4 ". From top of eye to bottom of threads. Finally
the proper name for that piece used inside the cable is a thimble, not a
shackle. I am getting as bad as M A M but at least my revisions come
faster,he, he. Regards, Geert Frank
