[rebel-builders] Rebel - Should you move your firewall back
[rebel-builders] Rebel - Should you move your firewall back 3
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:38 pm
Not for the faint at heart..I'll tell you that. My knees still knock when I
think about it! or may that was caused by the two CB's I flew between to get
to that point....
I don't think I'll get myself in that situation again...lets put it that
way!
Sent: Tuesday, January 30, 2007 9:44 AM
Subject: RE: [rebel-builders] Rebel - Should you move your firewall back 3
Hmmm, so you can spin a Rebel on floats and live. Good to know...
Sent: Monday, January 29, 2007 8:28 PM
Subject: Re: [rebel-builders] Rebel - Should you move your firewall back
3
Typical FULL loading usage on mine going up to the lake (44 gallons fuel,
me, flight bag, clothes, couple of 5 gallon cans in back to top for
coming
back home, tools, misc construction material, etc), on 1800 amphibs, puts
the operating C of G @ ~17" for a nice effortless/trimless cruise. Light
Warp drive prop, lightweight starter and O-320 Lyco on original firewall
positon. I did put my battery down the tailcone to be sure prior to the
float install...but I shouldn't have bothered as it would have been just
fine left on the firewall and when flying light a gallon of water in each
back float compartment would have fixed the nose heavy issue for me.
I also know it will recover from a spin...first I ever did with it in 10
years.....had to cork screw down thru a "hole" in August!
Sent: Monday, January 29, 2007 10:55 PM
3
When on amphibs, and even with the firewall cut back, hard to get much
more
than 13 c of g at 1730. But if you were to load it to 2000 (not saying
that
anyone does), that would also allow for some baggage, getting the c of
g
back to past 16, which is still well within the c of g. Again, that is
with
my 10.7 c of g empty amphib 0320 Rebel.
Best to use an excel spreadsheet to play around with different weights.
I like the idea of saving 80 pounds of wing lift by moving the c of g
back,
and also reducing/reversing the tail stress at the same time. Of
course,
that doesn't mean that the extra weight is free. Gross weight is still
gross
weight.
back
takes
clone
have
that
912S
own
sometimes
leaning
have
have
detailed
all
Rebel.
LOT
longer
have
