[rebel-builders] Rebel - Should you move your firewall back 3
Posted: Sun Feb 19, 2012 2:38 pm
by Jesse Jenks
WRT Daryl's letter,
I understand the efficiency gained by having a CG toward the aft of the
envelope, but the second loading example with the CG BEHIND the CP seems
extreme. I thought you had to have some down load on the tail to maintain
pitch stability, unless it's a fly-by-wire fighter where the computer makes
the elevator move 100 times a second just to fly level.
What Daryl talks about with the tail contributing to the wing lift, seems
like canard theory, only we're not flying backward.
I only have a basic theoretical understanding of this, and maybe some
airplanes have safe CG ranges in this realm, but is a CG of 18" on the Rebel
really AFT of the C of P?
Anyway, I'm not going to cut my firewall back, it seems like just using a
light prop is easier and better. Oh, and use thicker corner wraps.
Subject: Re: [rebel-builders] Rebel - Should you move your firewall back 3
Date: Tue, 30 Jan 2007 00:07:31 -0500
Yup It's easy to fix a forward C of G but not so if you're too far aft. My
most rearward loading is 17.66" without the firewall moved. I have a full
floor so if I really wanted to do math before each flight I could almost
always fly at the idea C of G. Daryl you say that 18" is well within the
envelope but the pilot operation manual you sent me gives the aft limit as
18.1"
At 11:27 PM 1/29/2007 -0500, you wrote:
Typical FULL loading usage on mine going up to the lake (44 gallons fuel,
me, flight bag, clothes, couple of 5 gallon cans in back to top for
coming
back home, tools, misc construction material, etc), on 1800 amphibs, puts
the operating C of G @ ~17" for a nice effortless/trimless cruise. Light
Warp drive prop, lightweight starter and O-320 Lyco on original firewall
positon. I did put my battery down the tailcone to be sure prior to the
float install...but I shouldn't have bothered as it would have been just
fine left on the firewall and when flying light a gallon of water in each
back float compartment would have fixed the nose heavy issue for me.
I also know it will recover from a spin...first I ever did with it in 10
years.....had to cork screw down thru a "hole" in August!
Sent: Monday, January 29, 2007 10:55 PM
Subject: RE: [rebel-builders] Rebel - Should you move your firewall back
3
When on amphibs, and even with the firewall cut back, hard to get much
more
than 13 c of g at 1730. But if you were to load it to 2000 (not saying
that
anyone does), that would also allow for some baggage, getting the c of
g
back to past 16, which is still well within the c of g. Again, that is
with
my 10.7 c of g empty amphib 0320 Rebel.
Best to use an excel spreadsheet to play around with different weights.
I like the idea of saving 80 pounds of wing lift by moving the c of g
back,
and also reducing/reversing the tail stress at the same time. Of
course,
that doesn't mean that the extra weight is free. Gross weight is still
gross
weight.
back
takes
clone
have
off
loaded.
about
Biggest
that
wash.
912S
own
sometimes
leaning
have
have
detailed
all
Rebel.
LOT
longer
more
have
FREE online classifieds from Windows Live Expo
