[rebel-builders] RE: Inspection holes in wings
Posted: Sun Feb 19, 2012 11:34 am
Ben,
Thank you. The ones by the strut attach point are the
only ones I figured I needed and was wondering if any
others were possibly needed for future use. I have
gotten the one lug nut plates from Wayne some time ago
so I will be using them for the aileron hinges and
will not be putting in the inspection holes for that
area. Thanks again.
Keith R661
--- bransom@dcsol.com wrote:
____________________________________________________________________________________
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
area. Thanks again.
Keith R661
____________________________________________________________________________________MAM calls for inspection holes in front of and
behind where the lift strut
ties to the wing (Chapter 10.10). They didn't call
for that in the
pre-1995 manual, so is it "mandatory"? I dunno.
They also called out
inspect holes at the aileron hinge points, but I
understand some people
don't do these because they instead use nutplates
for the hinge bolts, and
theoretically will never need to get inside there.
I like being able to
lay eyes on key points such as the lift strut attach
structure and felt
like I might as well put the holes in for the hinge
points too. On the
hinge points I left out the hole on the root or end
(left or right wing)
where the hinge nuts are outside. Making the holes
and getting the
doublers just right is a bit time consuming and to
some extent might not be
too bad adding after the plane has been flying.
-Ben /496R
forI think I may have asked this question before butcoverssome darn reason I can not access the rebel-list.
I am finally back in Hawaii and trying to pick up
where I left off on the wing construction and I am
wondering if it is necesary to put inspectionany where in the wings and where they would be
located.
Thank you,
Keith R661
-----------------------------------------------------------------List archives located at:
Do you Yahoo!?
