from the top of Fus-36 to the surface of Fus-31 is 5 5/8" (not 8") Jean.
If you have the 5/32 x RV1510's or 1512's then use them if you feel the hole
has gone beyond the expansion of an RV1410.
As for dimpling....I do not dimple any holes along the fus 30 to 31 joint or
the reinforce triangle for that matter. I've found that the fairings will
fit just as well going this way and infact the rivet heads actually keep the
fairings from chewing into the fus-30.
Sent: Sunday, January 07, 2007 12:49 PM
Subject: Re: [rebel-builders] site down?
When I place the horizontal bulk head #fus 31, I have drill the top of
the tab at 8" instead of the bottom surface of the bulk head. I have
discover it when I tried to take measures for the tail spring bulkhead
#fus-49. So I had to remake the tail wrap (I had 3 of them! One is use
to make the doubler ontario mod #1). But in the work, some holes in the
tabs of the one piece bulkhead #fus-36 have enlarged. I do have
5/32" avex rivets for those but some have to be dimple plus couple of ones
in the gussets/hrizontal bulk head... That is the result of a less
than perfect english, you can read but it always ask more concentration
than your first language and... you understand?
Jean
On Sun Jan 7 12:35 , 'Wayne G. O'Shea' <oifa@irishfield.on.ca> sent:
What area are you working in?
To: rebel-builders@dcsol.com>
Sent: Sunday, January 07, 2007 12:25 PM
Hello Wayne!
Everything look ok this morning.
A question... I made a mistake in the (not the first one!) and I had
remake a part. Because some holes (a lot) were already #30 when I
found it, The new part had to be drill direct to #30. Some hole of the
part that have been "drill" a "second time" have enlarge... The area
have some rivet that have to be dimple. 5/32" avex rivet will hard to
find and 3/16" are a bit big! Could I use contersunk 5/32" SS rivets
much easier to find for me?
Jean
Rebel 747R
On Sat Jan 6 14:39 , 'Wayne G. O'Shea' oifa@irishfield.on.ca> sent:
