When I place the horizontal bulk head #fus 31, I have drill the top of the tab at 8" instead of the bottom surface of the bulk head. I have
discover it when I tried to take measures for the tail spring bulkhead #fus-49. So I had to remake the tail wrap (I had 3 of them! One is use
to make the doubler ontario mod #1). But in the work, some holes in the tabs of the one piece bulkhead #fus-36 have enlarged. I do have
5/32" avex rivets for those but some have to be dimple plus couple of ones in the gussets/hrizontal bulk head... That is the result of a less
than perfect english, you can read but it always ask more concentration than your first language and... you understand?
Jean
On Sun Jan 7 12:35 , 'Wayne G. O'Shea' <
oifa@irishfield.on.ca> sent:
What area are you working in?
jean.poirier@oxyportneuf.com>
To:
rebel-builders@dcsol.com>
Sent: Sunday, January 07, 2007 12:25 PM
Subject: Re: [rebel-builders] site down?
Hello Wayne!
Everything look ok this morning.
A question... I made a mistake in the (not the first one!) and I had to
remake a part. Because some holes (a lot) were already #30 when I
found it, The new part had to be drill direct to #30. Some hole of the
part that have been "drill" a "second time" have enlarge... The area
have some rivet that have to be dimple. 5/32" avex rivet will hard to
find and 3/16" are a bit big! Could I use contersunk 5/32" SS rivets
much easier to find for me?
Jean
Rebel 747R
On Sat Jan 6 14:39 , 'Wayne G. O'Shea'
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
