CORROSION
Jones, Mike
CORROSION
Post by Jones, Mike » Fri Feb 17, 2012 5:46 pm
As usual very helpful info Bob. Can you tell me how to get in touch with
Northern Shield, it sounds like to much work and risk to properly cromate
the inside surfaces. I dont think I want to build a spray booth with all the
air supplies.
Mike#007
CORROSION
Post by Bob Patterson » Fri Feb 17, 2012 5:46 pm
Mike,
I wouldn't be in a big hurry to do anything to the inside. The
Epoxy Chromate Primer in the joints will protect them, and the large
open surfaces will go for many years without any problems - you could
wait, and do the treatment then, <if> you felt it necessary. It is easy
to do at any time, so there's no rush.
Northern Shield could be good protection for the inside, IF
you wanted to do it. It must be applied with a long 'wand' which blows
it in as a mist which creeps to coat all surfaces, then hardens to
a waxy state. It should last for many years. The 'wand' can be rented
(I think), or can be purchased from the company - contact:
Bob Marsh, National Sales Manager,
Northern Shield Protective Coatings,
4391 Harvester Road, Unit 9,
Burlington, Ontario L7L 4X1
Tel.: (905) 631-7887 Fax.: (905) 631-8105
Let him know that you heard about it through me and the RAA-TR
Rebel Builders of Ontario group - they will give you a good price !
(Bob did a presentation on the product at a meeting a few years ago ...)
The wands are expensive - about $200, I think, but the treatment
itself is cheap - about $35 for enough to do a complete aircraft !!!
--------------------------------orig.-----------------------------------------
air supplies.
Mike#007
Doug Martin
CORROSION
Post by Doug Martin » Fri Feb 17, 2012 5:46 pm
I made a wand by buying the longest steel brake line from the local auto
parts store then attaching it to a garden (pump up)sprayer with some
nozzles from the garden supply. That way I have nozzels that will shoot 90
degrees to stright out
At 09:06 PM 4/17/2000 -0400, you wrote:
Mike,
air supplies.
Mike#007
Doug Martin
greyghost@powernet.net
