[rebel-builders] Re Jabiru and high speed prop
Post by Bob Patterson » Sun Feb 19, 2012 11:30 am
Thanks John !
Had a nice tour around the Aussie Web Ring from that page !
The correct link is: www.boydair.com
It was interesting to see the mods on the Jabiru engines -
they all seem to have gone to the Rotax 4-into-1 tank mufflers,
likely to gain some power. The additional cooling mods were
interesting - maybe some airflow issues, and the oil cooler ...
All show it as a work in progress - as are many of the new engines.
That prop certainly looks substantial - wonder about the cost ?
Wish more manufacturers would provide easy, accurate ways to
adjust blade pitch, like the new Sensenich, with just one adjusting
bolt in the center. It used to take a full day to get a Warp Drive
or GSC prop set right (and even !) ... :-(
Two-blade props are always more efficient than 3 blades, but
I guess the Jabiru aircraft has a limit on diameter - in addition
to the limit imposed by the high rpm necessary to develop power.
http://www.prosumers.ca
On Tuesday 12 December 2006 01:08, gleeso wrote:
G'Day All, came across a three blade prop specifically for the 3300 Jab
at a local fly in recently. It is made for the Jabiru, which is a lot
more slippery than a Rebel but it may work on a Rebel. Check out
www.boydair.com.au They are not far away from me so I'll give them a
call tomorrow and see what I can find out.
I too am building to suit our RA Aus 600 KG MTOW, and the engine is
still a ways off yet.
Regards
John Gleeson
Rebel 804 down under
