[rebel-builders] Sealant spread
Posted: Sun Feb 19, 2012 2:30 pm
I guessed something like that. I was also thinking that with so much
sealant you must have a heck of a cleanup job afterwards on the
exterior. I wasn't planning on being quite as generous with the sealant
as I was with the fuel tanks but maybe I should be.
Since I have a bunch of proseal and since I'd like to keep the bottoms
resistant to any leaked hydraulic fluid, anti freeze, etc. I plan to use
it for at least the lower skins. In my cool basement it seems to take
forever for the stuff to setup anyway. Seems silly to ask if the two
stickiest substances that I know of will stick to each other but has
anybody tried that?? I'm guessing that the proseal will soften the
sikkaflex and probably adhere nicely??
Wayne G. O'Shea wrote:
BTW..for those that have the Float Build CD and are wondering how I did the
sealant spread over rivet heads as shown in the pictures. I just take a wood
tongue depressor..cut it off square and then add a notch in the center just
slightly wider/deeper than a rivet head. Makes for a clean cover seal
without waste/extra weight and it's neat.
