[Heat Shrink
Jim Cole
[Heat Shrink
Post by Jim Cole » Sun Feb 19, 2012 11:30 am
I think someone last week mentioned that they used "clear heat shrink" over
labels on the ends of the their wires??
I am at the same spot and would like to identify the wires this way.
Where do you get "clear" heat shrink?
Jim Cole
Rebel 333
On 11/30/2006 2:32 PM, "Brad Hewlett" <bhewlett@sasktel.net> wrote:
On this note. (you brought it up)
What is the best way to remove old proseal?
Brad Hewlett
Saskatoon, SK
Sent: Thursday, November 30, 2006 9:50 AM
Subject: Re: [rebel-builders]Sealant for Access panels in fuel tanks
DOW 730 is a sealant that the military uses on panels that need frequent
entry ... will work, but is expensive. Over 75US per tube if you can find
it,
and it expires quickly also. I have some that I am going to test on my
Grumman alongside with the low adhesion pro-seal on adjacent cover to see
the difference. I HATE cleaning off old pro-seal.
