[rebel-builders] Access panels in fuel tanks
Posted: Sun Feb 19, 2012 2:27 pm
Hopefully the guys will help you out Dale. Like I said I seal those things
shut before I even place the lower tank skin on the wing.
Sent: Wednesday, November 29, 2006 1:13 PM
Subject: [rebel-builders] Access panels in fuel tanks
What is being used on the access panels in the fuel compartments of the
wings to seal them up? Is there a proseal that is used ? I need to get
mine
sealed up to fire engine up. I emailed MAM but didn't get a reply and
didn't
see anything in the manual.. Thanks Dale SR-033
by Steve Halvorsen
Dale
Proseal the hell out of the plates and BE SURE to use the closed end revits to hold the plates on.
Key here is to get a good seal use the correct revits for the job.
If the standard revits are used the stems will leak AT SOME TIME.
Steve H
Moose 213
Sent: Wednesday, November 29, 2006 12:13:42 PM
wings to seal them up? Is there a proseal that is used ? I need to get mine
sealed up to fire engine up. I emailed MAM but didn't get a reply and didn't
