A question for all of you who have built the rudder/elevator:
How did you de-burr the 70+ rivet holes inside the rudder/elevator spar
tubes?
Any suggestions appreciated.
Roger #687R
Rudder/Elevator Spars-deburring
Bob Johnson
Roger & Alice- When I built my units I ran very fine emery paper taped over
foam rubber(carpet underlay) which was stapled to a 3/4 dowel. The larger
end holes where easily accessible with the std. swivel deburring tool-Best
regards-Bob J. Rebel "652"
Sent: Monday, April 10, 2000 12:26 PM
Subject: Rudder/Elevator Spars-deburring
*---------------------------------------------------------------------------A question for all of you who have built the rudder/elevator:
tubes?
Roger #687R
*---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
