ProSeal storage
ProSeal storage
Post by Mike Davis » Fri Feb 17, 2012 4:21 pm
Received: from albedo.net (ppp115.albedo.net [206.51.22.134]) by
juliet.albedo.net (8.8.3/8.6.9) with ESMTP id JAA27619 for
<murphy-rebel@dcsol.com>; Tue, 14 Apr 1998 09:02:12 -0400
Message-ID: <35335E29.D7E76EE0@albedo.net>
Date: Tue, 14 Apr 1998 09:01:29 -0400
X-Mailer: Mozilla 4.04 [en] (Win95; I)
MIME-Version: 1.0
Subject: ProSeal storage
References: <6758262c.34f8a1de@aol.com> <34FB5B58.7A615C11@planeteer.com>
For long term storage of pro-seal (at least 2 years), I know that it should
be
refrigerated. Does anyone know if putting it in a freezer (-18C) would be
even
better?
thanks
ProSeal storage
Received: from JimsRebel@aol.com
by imo25.mx.aol.com (IMOv14.1) id GVDAa15615
for <murphy-rebel@dcsol.com>; Tue, 14 Apr 1998 12:24:57 -0400 (EDT)
Message-ID: <e0b3accb.35338dda@aol.com>
Date: Tue, 14 Apr 1998 12:24:57 EDT
Mime-Version: 1.0
Subject: Re: ProSeal storage
X-Mailer: AOL 3.0 for Windows 95 sub 49
Hi ProSeal Warriors
When I worked at Boeing , they stored ready mixed ProSeal in a very very
cold
freezer in the parts room. Then you put the tube under hot water until it
was
at room temp. I bought some tubes of two part ProSeal as I have a air gun
used
with these tubes and you can lay down a bead very nicely. The factory tech
rep.said you can store mixed Pro-seal packed in dry ice in a box in the
freezer for a few days. I stored all my proSeal in the freezer for about a
year and it seem to work out fine. The 6 month date on the tubes is more
like
a garrentee of freshness then a life limit as the factory will retest it and
relabel it if its past the 6 month date ( they delayed my shipment to retest
there stock , I wonder how old it really was ). So if it mixes up ok you can
still use it.
You can also thin it with MEK after you mix it ( just once ) to brush it
with a acid brush . I brushed most of my ProSeal layers.
Good luck. Jim LePard rebel254 JimsRebel@aol.com
ProSeal storage
Received: from ts76-04.tor.istar.ca [204.191.146.147]
by mail1.toronto.istar.net with smtp (Exim 1.80 #5)
id 0yP95T-0005yd-00; Tue, 14 Apr 1998 13:01:36 -0400
Mime-Version: 1.0
Message-Id: <E0yP95T-0005yd-00@mail1.toronto.istar.net>
Date: Tue, 14 Apr 1998 13:01:36 -0400
YES !! Most refrigerators have automatic defrost, which thaws things
out.
A freezer is a much better place for storage.
....bobp
--------------------------------------orig.--------------------------
be
even
better?
thanks
ProSeal storage
Received: from tim.intrixsg - 153.35.236.46 by email.msn.com with Microsoft
SMTPSVC;
Tue, 14 Apr 1998 10:56:17 -0700
Received: by localhost with Microsoft MAPI; Tue, 14 Apr 1998 10:54:37 -0700
Message-ID: <01BD6793.B7B22200.tlcarter@email.msn.com>
Reply-To: "tlcarter@msn.com" <tlcarter@msn.com>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: RE: ProSeal storage
Date: Tue, 14 Apr 1998 09:27:12 -0700
X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
MIME-Version: 1.0
Return-Path: tlcarter@email.msn.com
Yes.
Freezer is much better if sealed airtight so that the dry air does not
cause the Proseal and catalyst to dry out itself (same as freezer burn on
meat).
Reply To: murphy-rebel@dcsol.com
Sent: Tuesday, April 14, 1998 6:01 AM
To: (Murphy Rebel)
be
even
better?
thanks
ProSeal storage
juliet.albedo.net (8.8.3/8.6.9) with ESMTP id PAA01052 for
<murphy-rebel@dcsol.com>; Tue, 14 Apr 1998 15:42:24 -0400
Message-ID: <3533BA9B.C90F5B30@albedo.net>
Date: Tue, 14 Apr 1998 15:35:55 -0400
MIME-Version: 1.0
References: <E0yP95T-0005yd-00@mail1.toronto.istar.net>
Thanks for the advice guys!
It's sealed and frozen.
