Hello
I am ready to fit the inside corner wrap in the tail cone section. Manual say to fit a corner wrap between bulkhead "C" and "D" an then continu
up to bulkhead "A". That mean half corner wrap between C and D and then a complete one between C and A. Is my understanding OK?
The manual do not say a word about riveting that section... In my logic, I should rivet everything except at A and E bulkhead... is it ok? ( I
know I should probably call the guy who my inspection before close the floor....)
Thanks again
Jean
Rebel 747R
inside corner wraps....
Hi Jean
Looks like I'm still just barely ahead of you. ;) I think I recall others
saying to make the floor and corner wraps go all the way back. I used full
length ones between A-C and C-E. I also found it fairly easy to make them
from stock if you need to buy more <a
href="http://mae.ucdavis.edu/ransom/Murphy/09 ... cture).</a>.
Yes, rivet inside corner wraps at each bulkhead. Use lexan as per MAM and
others to be careful to hit the narrow width of the bulkheads <a
href=http://mae.ucdavis.edu/ransom/Murphy/10 ... icture)</a>.
I didn't close (rivet) my inside corner wraps or floor yet because in doing
the next tail area backward (Fus-29 and 30, tail post area), you will need
to drill out from the inside of Bulkhead E. An inside corner wrap there
would prevent that.
-Ben /496R
would prevent that.
-Ben /496R
Manual say to fit a corner wrap between bulkhead "C" and "D" an then continuHello
a complete one between C and A. Is my understanding OK?up to bulkhead "A". That mean half corner wrap between C and D and then
I should rivet everything except at A and E bulkhead... is it ok? ( IThe manual do not say a word about riveting that section... In my logic,
floor....)know I should probably call the guy who my inspection before close the
Thanks again
Jean
Rebel 747R
