Header tanks and injector return lines.....
Posted: Fri Feb 17, 2012 5:46 pm
Anyone out there using a header tank with fuel return lines AND a fuel
flow turbine? My LOM is fuel injected. I have two options as I see it
(I am open to others):
1. Run the return line through a 6 port / 3 position selector which
directs the return flow into the originating tank. Place the fuel flow
turbine after the selector. Drawbacks -> The turbine will be
inaccurate all the time and the fuel return lines add complexity.
2. Use a header tank with the selector before the header tank. The
return line comes back to the header tank and the flow turbine is placed
up stream of the header tank. Drawbacks -> Header tank adds complexity
& weight and the return line might induce bubbles in the fuel line.
So, does anyone out there use a header tank with a fuel return line into
it? Does the fuel injector return line cause any air bubbles to be
introduced in the fuel supply line?
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Best Regards,
Scott Hibbs
hibbs@pacifier.com
