[rebel-builders] Good advice from older builders (sorry longer then I plann
Posted: Sun Feb 19, 2012 2:26 pm
by Dale Fultz
Yes Tom there are important things need changed but as far as making a lot
of advancements and changes (structure problems or safety items by all means
do) I wonder if all the extra time is really worth it in the end.
The nose bowl you ask about , what are you using the top and bottom
full cowling or just the front fiberglas nose bowl if you are using just the
front nose bowl, I went into the rebel builders site under rebels and got
ideas from the guys that used the nose bowls for there Rebels. The four door
cowl design worked well for me. . Dale SR-033 N269DF
