[rebel-builders] Location of the seat rail
Posted: Sun Feb 19, 2012 2:21 pm
by Ken
We'd like to help but you need to give us more info or be more specific
I think.
What page of the manual or what diagram?
What is the date of your manual?
My 1993 manual details the side to side position of the under floor
channels. Those measurements are to the center of the channels. The seat
rails rivet into those channels. The seat section basically says to
assemble the seat frame and match the rail spacing to the seats so that
the seats slide freely. I can't seem to find this info on the newer
electronic version of the manual that I have. Think I'm missing that
section. I don't really understand what you are asking I guess. I do
remember matching the side to side spacing of the underfloor channels to
where the seat rails were going to go.
David L. Tuck wrote:
Thanks for all the info about the rails.
I do need to know about the measurment that is in the man ? is the distance
measured to the center of the rail or the foot of the rail ? that is where
they get rivited ?
I'm about to locate them and drill, but do want them correct first.
Dave T rebel #009
by Ian Donaldson
G'day
While we are on the subject of seat rails I bought an extra length from the
factory and extended both the seat rails.
By doing this, it allows a huge range of adjustment for all sizes of pilots,
and allows me to slide the pilot seat a loooong way back which makes it a
whole lot easier for me to get in.
The extra length of rail does not interfere with anything and is worth
doing!
regards
Ian
: Thanks for all the info about the rails.
: I do need to know about the measurment that is in the man ? is the
distance
: measured to the center of the rail or the foot of the rail ? that is where
: they get rivited ?
: I'm about to locate them and drill, but do want them correct first.
: Dave T rebel #009
by Drew Dalgleish
Ian If your seat latch fails would you still be able to reach the controls
with the seat all the way back? There's an AD on cessna seats calling for a
limit block after too many crashes caused by seat latch failures. I always
check my latch by wiggling the seat forwards and backwards after I have it
where I want it and once in a while it will slip out of position.
At 05:07 PM 11/5/2006 +1100, you wrote:
G'day
doing!
regards
Ian
distance
: Dave T rebel #009
Posted: Sun Feb 19, 2012 2:26 pm
by Ian Donaldson
G'day Drew
If the latch failed there is no doubt that it would make things very
difficult! (Unless you have elastic arms)
However all that I do, is when I am settled in the seat, is reach behind me
and place a small bolt in one of the holes in the seat rail. Simple and
easy.
Regards
Ian
: Ian If your seat latch fails would you still be able to reach the controls
: with the seat all the way back? There's an AD on cessna seats calling for
: limit block after too many crashes caused by seat latch failures. I always
: check my latch by wiggling the seat forwards and backwards after I have it
: where I want it and once in a while it will slip out of position.
: At 05:07 PM 11/5/2006 +1100, you wrote:
: >G'day
: >While we are on the subject of seat rails I bought an extra length from
: >factory and extended both the seat rails.
: >By doing this, it allows a huge range of adjustment for all sizes of
pilots,
: >and allows me to slide the pilot seat a loooong way back which makes it a
: >whole lot easier for me to get in.
: >The extra length of rail does not interfere with anything and is worth
: >doing!
: >regards
: >Ian
: >: Thanks for all the info about the rails.
: >: I do need to know about the measurment that is in the man ? is the
: >distance
: >: measured to the center of the rail or the foot of the rail ? that is
where
: >: they get rivited ?
: >: I'm about to locate them and drill, but do want them correct first.
: >: Dave T rebel #009
: > List archives located at: https://mail.dcsol.com/login
: > username "rebel" password "builder"
: > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
: > List administrator: mike.davis@dcsol.com
: Drew
: List archives located at: https://mail.dcsol.com/login
: username "rebel" password "builder"
: Unsubscribe: rebel-builders-unsubscribe@dcsol.com
: List administrator: mike.davis@dcsol.com
Also the reason to have elevator trim and always have it set for what you
are doing at the time. If the seat flies back during take off let go of the
,,,,, stick.
Sent: Sunday, November 05, 2006 6:16 PM
Subject: Re: [rebel-builders] Location of the seat rail
G'day Drew
me
easy.
Regards
Ian
controls
for
always
it
: >G'day
pilots,
: >doing!
: >regards
: >Ian
: >distance
where
: Drew
by Drew Dalgleish
Excellent suggestions thanks guys.
,,,,, stick.
G'day Drew
me
easy.
Regards
Ian
controls
for
always
it
: >G'day
pilots,
: >doing!
: >regards
: >Ian
: >distance
where
: Drew
