1800 float manual
1800 float manual
Post by Ken » Sun Feb 19, 2012 11:21 am
I assume that the bottom flange angle for bulkhead G is not correct in
Fig 4 on page 3-4 dated 03/27/95. The bottom flange angle of bulkheads D
through F is 90 degrees and it would seem that it should also be 90* on
G. Also the flange has to be 90* to match the 90* angle on the FL-37
angle that is rivetted to the other side of the bulkhead I think. Hope
this saves someone a bunch of head scratching or someone tells me why
I'm wrong... ;)
I notice the pics at the end of chapter 5 show the FL-36 attach angle
installed upside down on bulkhead G compared to Fig 16a of chapter 3.
Since Fig 16a would seem to be an improvement and since I found a pic
from Wayne that shows it as per the diagram, I believe Fig 16a is correct.
