[rebel-builders] Rebel - Flapperons vs. flaps?
Posted: Sun Feb 19, 2012 2:20 pm
by Bob Patterson
Hi Jim !
You don't get the same feeling of decelleration, but you can get
quite a steep descent at 70 - 75 mph ... and you don't want to be
much slower. Sideslips will only be necessary if you are REALLY
high !! ;-) ....but they work VERY well ! Slow to about
60 - 65 to lower the flaps, then push over to 75 or so for final.
The flapperons don't cause as much drag as the Cessna flaps,
so there's no problem taking off with full flap. Some Rebels
will climb better with 2 notches instead of full, at 65 mph.
The Moose flies just like a BIG Rebel in the air - it's just
a bit more sedate about it. ;-) Glad you liked it.
The Moose is a big limo - the Rebel is a sports car ! ;-)
Both nice - just different.
On Sunday 22 October 2006 08:19 pm, pequeajim@dcsol.com wrote:
Bob:
Do the flapperons have the same affect as regular flaps when on final. My
experience is mostly in a 172 and at 30 degrees of flaps, they slow me down
very nicely. I have been practicing with 1-20 flaps and slipping to gain
more
experience. I know that the flapperons provide better low speed handling,
but do they also provide the same drag effect as regular flaps?
Jim!
On 10/22/2006 7:39 AM, beep@sympatico.ca wrote to rebel-builders:
-> I always take off and land with full flap - the Rebel was
-> designed for that, as it changes the whole airfoil, allowing
-> good low speed handling. The slower you can touch down, the
-> safer you are going to be ! I've landed on wheels with 25 mph
-> at 90 degrees - only one runway ... and on amphibs in a
-> wind that was 45 degrees off the runway, at 38, gusting 47 !
-> The Rebel is really good in crosswinds, as it has lots of
-> rudder. You DO have to FLY IT all the way to the tiedowns -
-> use ailerons (opposite as required) on the corners -- as you
-> should with any taildragger.
