[rebel-builders] Another flapperon question
Posted: Sun Feb 19, 2012 11:16 am
Hi Jim !
Never seen anybody use plastic washers ! Many run a strip of
fabric tape over the base fabric over the ribs, then rivet with
the large head fabric rivets, and then cover the rivets with a
final strip of pinked edge fabric. All of these strips are,
of course, soaked in Polyfiber and allowed to dry before
continuing. :-)
DO bend the sharp edges of rib flanges down slightly so
they aren't cutting into the fabric. Maybe cover sharp spots
with fabric patches or just tape before final covering,
if you can't round them.
Go ahead & give it a shot - worst that can happen is you'll
have to peel off some burnt fabric & try again !! ;-)
Get it flying - it'll never be finished !!! :-)
We want more Rebels for Ramble 2007 - get them FLYING !!
On Friday 20 October 2006 12:06 pm, pequeajim@dcsol.com wrote:
continuing. :-)
anGuys; thanks for your patience.
When you use the fabric rivets, are you also putting a thin plastic washer
under the head of the rivet to keep the fabric from tearing, or is this not
issue?
