primer lines
Jones, Michael
primer lines
Post by Jones, Michael » Sun Feb 19, 2012 11:16 am
hi all
has anyone out there done the soldering of primer lines, i understand i
should use silver solder on the ends of the primer lines because of its
higher melting point, which makes sense, the only solder i have found so far
at stores near me is lead free solder with some silver content, with melting
point of approx 500 deg c, would this be okay to use, or does anyone in
canada know a local supplier of better silver solder
thank
mike#007
