0-235, and other stuff for sale
rebflyer
Post by rebflyer » Sun Feb 19, 2012 11:16 am
Hi all,
I have an 0-235c1(conical style mount) with 560 hrs since new for sale. Mags, starter, vacum pump, alt, carb. With log book. 8000.00 US
Also 4 blade warp drive prop, and used Yarworski(sp) wing mount light kit.
Sorry about posting them here.
Contact me off list for more details
Curt Martin
Rebflyer@aol.com
Sent: Fri, 6 Oct 2006 11:08 PM
Subject: Re: [rebel-builders] Rebel -fuselage floor inner cone
Hi Jean !
I'm with Ralph ! I have some good feedback from structural tests
that the rear floor is indeed a great contributor to fuselage strength !
I would go with rivets.
As several have suggested, I drilled 1/8" holes in front of the
bulkheads - you could put a few in the channels if you wanted. Probably
a good idea to coat the inside belly skin with epoxy primer - you won't be
in there again for a long time.
One winter, long ago, I was surprised to find a large block
of ice in the rear fuselage, just from snow blowing in the gaps
and melting over a couple of weeks ! The next day, I crawled under
and drilled those holes in the belly skin !!
On Friday 06 October 2006 09:40 pm, Ralph Baker wrote:
Jean,
I'm going to disagree with Bob (first time for everything I guess). The
inner floor does for a "box" and adds substantial rigidity to the assembly.
I come down of the rivet side for max strength. Do however think way ahead
and make provision for anything which you may want under the floor in the
future. An example might be marker beacon antenna leads or fuel lines.
________________________________________________________________________
Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more.
