If you have did the leading edge rib 6 " out from the root and the W161
forward attach reinforce angles and have a .063 main spar.... your Gross
weight per MAM is 1650lbs Gary....if you have the 1650 gear legs (ie 1 1/4"
main leg with 1" stub at top for attachment)
Sent: Sunday, October 08, 2006 11:28 PM
Subject: [rebel-builders] Allowable Gross Weight
[quote]In reading the Safety Bulletin 071095RB, I read the following about Gross
Weight::
