Pro-Seal cure time has me scared.............
Posted: Fri Feb 17, 2012 8:45 pm
I had some excellent suggestions on Pro-Sealing my tanks, including the
suggestion that I buy new Pro-Seal. I bought a couple of quarts from
Van's Aircraft here in Portland and it is dated 12/99.
The problem is that the gunk is still the same sticky consistency that
it was yesterday when I started. I applied heat overnight (bulb in the
tank) but it has not cured at all!
Known:
Mix ratio was 10:1, I have gone over and over the mix steps and ratio
was 10:1
Humidity outside is pretty high ( 80-100%) but with the element heater I
use in the garage, it is probably 50-75% inside.
Possible issues
Wrong accelerant or Proseal - the can does say MIL-S-8802F TY II CL B2
(the F is not on my P/S spec sheet)
Also, I just noticed that the can also has the numbers 236 B-2 stamped
on it. Anyone know if that is significant?
Maybe long cure times are normal (doubtful - as it suggests you have
limited time to work with it once mixed).
I would appreciate any insight you folks have. I suspect at the least I
have to strip it all off and clean it up.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Known:
was 10:1
Possible issues
Best Regards,
Scott Hibbs
hibbs@pacifier.com
