wt & bal
Posted: Sun Feb 19, 2012 11:13 am
Just to throw my two cents in re: wt. & bal.--- On SR 96CS, I found that the moment arms listed in the manual were not appropriate. With the airplane leveled, I dropped plumb lines from all of the locations (datum point, front seat in flight position, average fuel tank arm {a/c was weighed with unusable fuel in the tanks}, rear seats at normal rear location, tail wheel, AND THE ACTUAL CENTER OF THE BAGGAGE COMPT. Using these figures, and scale weights to determine empty cg, I came out with what I believe is a realistic set of numbers for my aircraft. Incidentally, my a/c came out a good bit heavier than I would have thought, at about 2000#. Just shows that every little piece adds weight. But still, I can carry 4 people, 80# baggage and 4 hours fuel - and flew to OSH with max weights.
Charlie Starr 065SR
Charlie Starr 065SR
