I installed 5/16 nutplates inside the rear tube, but it's probably too late
if you already have everything riveted together. I think the manual says to
cut oversize holes to get sockets in there.
Jesse
Subject: [rebel-builders] Rebel landing gear
Date: Thu, 28 Sep 2006 16:56:03 -0400
Hello all,
I'm looking ahead trying to avoid "gotchas". When I look at the install of
the slide tube assembly (fig 15.1.2) it appears the instructions were
written for the half tubes across the bottom of the cage. AN5-20 bolts
would be long enough in that case. However, I used the full tubes. So what
does one do?
I can drill over size holes in the front and rear faces of the cage tubes
so that I can insert sockets and use the -20 bolts or get longer bolts and
go all the way through. My instinct is that bolts that long would not be a
good idea. Too much opportunity to wiggles and stretch.
Any thoughts??
Allen Poulsen
786R
