[rebel-builders] Rivet strength
apoulsen
Post by apoulsen » Sun Feb 19, 2012 11:13 am
Hi,
It may be heresy to mention his name here, but Chris Heintz has some good
information on his site.
http://www.zenithair.com/kit-data/ht-87-1.html
Another consideration that I read somewhere.... Often the spacing of the
rivets is based on the need to use more rivets to keep the joint flat than
are necessary to carry the shear load giving an extra margin of strength.
More food for thought.
Allen Poulsen
786R
Sent: Wednesday, September 27, 2006 11:34 AM
Subject: [rebel-builders] Rivet strength
I recently had a short discussion with Darryl Murphy regarding the use of
Avex pull rivets vs solid rivets. In summary, Darryl pointed out that the
shear strength of the skin in most places (e.g. 0.025 thickness I believe
he
was using as an example) is only about 165lbs. Hence, his contention is
that the Avex is plenty strong enough--to go stronger (his point) means
that
the skin fails versus the rivet failing.
Also, there doesn't seem to be any instance (that I'm aware of) where an
Avex rivet installation failed on a Rebel, SR or Moose that caused any
problem (that would otherwise have been prevented thru the use of a solid
rivet).
Food for thought...
eric.r@dcsol.com
Sent: Wednesday, September 27, 2006 9:25 AM
Subject: Re: [rebel-builders] RE: Dimpled Rivets
O.K., I have a question on the rivet substitution chart. Am I reading
correctly that a dash-3 solid aluminum rivet is far superior in bearing
shear to any avex 1/8 installation?
On 9/26/2006 7:53 PM, mike.davis@dcsol.com wrote to rebel-builders:
-> No problem, I've moved it into General Documentation.
-> Mike
-> From: "Dale Fultz" <dfultz17086@earthlink.net>
-> Sent: Tuesday, September 26, 2006 7:05 PM
-> Subject: Re: [rebel-builders] RE: Dimpled Rivets
-> > Hi Mike,,, Sorry to cause you problems, I guess I got the rivet
-> > chart in the wrong section could you put it in the appropriate
-> > place so everyone can find
-> > it.. I believe it is in the Elite Misc. file section.. Thanks Dale
-> > SR-033
-> > ----- Original Message -----
-> > From
password "builder"
Post by Mike Davis » Sun Feb 19, 2012 11:13 am
Hmm... and here I thought they used so many rivets simply because deburring
is so much fun!
Hi,
Allen Poulsen
786R
rickhm
Post by rickhm » Sun Feb 19, 2012 11:21 am
Mike,
You don't know what fun is! I flush rivetted the entire airframe which means I dimpled the whole thing too. Now that's real fun!
is so much fun!
Hi,
Allen Poulsen
786R
mike.davis
Post by mike.davis » Sun Feb 19, 2012 11:21 am
Anybody got the number of a good shrink?
On 11/4/2006 10:42 AM, rebel-builders@dcsol.com wrote to MIKE DAVIS:
-> Mike,
-> You don't know what fun is! I flush rivetted the entire airframe which
-> -------------- Original message --------------
-> From: "Mike Davis" <mike.davis@dcsol.com>
-> > Hmm... and here I thought they used so many rivets simply because
deburring
-> > is so much fun!
-> > Mike
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:21 am
Glad you said it...I sure thought it! ;o)
Sent: Saturday, November 04, 2006 7:12 PM
Subject: Re: [rebel-builders] Rivet strength
-> Mike,
deburring
-> > Mike
eric.r
Post by eric.r » Sun Feb 19, 2012 11:21 am
We are keeping the name and number for the shrink a secret. It's the only
way to get his great price break on the dimple frame!
On 11/4/2006 3:28 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Glad you said it...I sure thought it! ;o)
-> From: <mike.davis@dcsol.com>
-> Sent: Saturday, November 04, 2006 7:12 PM
-> Subject: Re: [rebel-builders] Rivet strength
-> > Anybody got the number of a good shrink?
-> > On 11/4/2006 10:42 AM, rebel-builders@dcsol.com wrote to MIKE DAVIS:
-> > -> Mike,
-> > -> You don't know what fun is! I flush rivetted the entire airframe which
-> > means I dimpled the whole thing too. Now that's real fun!
-> > -> -------------- Original message --------------
-> > -> From: "Mike Davis" <mike.davis@dcsol.com>
-> > -> > Hmm... and here I thought they used so many rivets simply because
-> > deburring
-> > -> > is so much fun!
-> > -> > Mike
