I checked out the fuel cap included in my kit. The cap is steel and the neck
aluminum. After only a few turns I noticed serious wear on the aluminum
edges that contact the steel locking tabs. Is this just initial break-in I'm
seeing or does it continue to wear and eventually loose grip?
Comments welcome!
Paul Kucera , Rebel 453R
Fuel cap
Fuel cap
Your following message has been delivered to the 149 members of
the list murphy-rebel@dcsol.com at 21:17:47 on 16 Mar 2000.
Paul, 5 years+ of flying and a lot of fill ups, my caps are still snug to
turn into to place. Have not noticed any real "wear" and they definitely
won't fall off. Check yours for a possible burr or slightly grease to stop
the galling.
Regards,
Wayne G. O'Shea - 243R and numerous others!
Date: Thursday, March 16, 2000 8:54 PM
Subject: Fuel cap
the galling.
Regards,
Subject: Fuel cap
neckI checked out the fuel cap included in my kit. The cap is steel and the
I'maluminum. After only a few turns I noticed serious wear on the aluminum
*----------------------------------------------------*seeing or does it continue to wear and eventually loose grip?
Comments welcome!
Fuel cap
Thanks Wayne. Installed it last week. Just a tad of silicone spray on the
underside of the rubber seal helped.
Paul Kucera.
Sent: Thursday, March 16, 2000 9:10 PM
Subject: Re: Fuel cap
Paul Kucera.
*----------------------------------------------------*Paul, 5 years+ of flying and a lot of fill ups, my caps are still snug to
the galling.
Regards,
Subject: Fuel cap
neckI checked out the fuel cap included in my kit. The cap is steel and theI'maluminum. After only a few turns I noticed serious wear on the aluminum
edges that contact the steel locking tabs. Is this just initial break-in*----------------------------------------------------*seeing or does it continue to wear and eventually loose grip?
Comments welcome!
